a/f gauge install
I'm not sure if this is the right section, but it seemed to be my best option.
I'm getting ready to put an a/f gauge in my 94 Prelude, and was curious about how I should run the wire to get from inside the car (the gauge of course) to outside and underneath to my o2 sensor? I know I've got a power wire and a ground wire to hook up but where does the sensor wire go? Thanks guys
This should probably be in the tech forum.
But I'm a stickler for running wires in stock locations and would probably try to feed the wire through the factory grommets on the firewall where the engine harness comes through. It's pretty difficult, but it looks the best in the end, though.
Sorry if the second post "offended you" so much man, I just wasn't sure which section it belonged in so I figured I'd try both. I've been given a little bit better since of direction on my other thread and am looking/reading into wideband o2's.
Thanks anyways though!
civicnar
Feb 26, 2004 05:22 PM
