a/f gauge install
Old Dec 3, 2007 | 10:14 AM
ECX's Avatar
ECX
* B A N N E D *
Default a/f gauge install
I'm not sure if this is the right section, but it seemed to be my best option.
I'm getting ready to put an a/f gauge in my 94 Prelude, and was curious about how I should run the wire to get from inside the car (the gauge of course) to outside and underneath to my o2 sensor? I know I've got a power wire and a ground wire to hook up but where does the sensor wire go? Thanks guys
Old Dec 3, 2007 | 11:19 AM
White Smoke's Avatar
i my honda
Global Mod
Default Re: a/f gauge install (ECX)
The best place to get the signal from is at the ECU itself. You will not have to run any wires into the engine bay whatsoever and you won't have to worry about getting under the car. Get an ECU pin out for your car and that should show you exactly where the primary 02 signal wire is.
You know your gauge is only going to be as accurate as your sensor? Which is only from ~14.3-15.1 AFR... Otherwise it's just a fancy light show.
Old Dec 3, 2007 | 12:12 PM
B18C_EJ8's Avatar
Default Re: a/f gauge install (White Smoke)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by White Smoke &raquo;</TD></TR><TR><TD CLASS="quote">You know your gauge is only going to be as accurate as your sensor? Which is only from ~14.3-15.1 AFR... Otherwise it's just a fancy light show.</TD></TR></TABLE>
True that... If you're concerned about AFR's, get a wideband.
Old Dec 3, 2007 | 05:31 PM
ECX's Avatar
ECX
* B A N N E D *
Thanks for the insight guys. I've heard alot of good things about Innovate's LC-1 stuff, should I go with that?
http://www.powertraincontrolso...id=40
Does this mean my gauge is useless (if I get a wideband vs. the stock narrowband)?
It's an Autometer Sport-Comp gauge, looks like this:
Old Dec 3, 2007 | 05:49 PM
B18C_EJ8's Avatar
That gauge is pretty much useless... It's really inaccurate. If you're just looking for some "bling", then by all means, run it.
However, if you're looking for something to monitor the actual air/fuel ratio, get a wideband. The Innovate one is good. Lots of people run them. However, the link you posted is just the controller. No gauge is included.
I myself run the PLX unit: http://www.plxdevices.com/products/dm5/afrsmcombo/. Gives you the light show () and the actual A/F ratiofront & center.
Old Dec 3, 2007 | 06:01 PM
ECX's Avatar
ECX
* B A N N E D *
Default Re: (B18C_EJ8)
Thanks for the help man, much appreciated.
Old Dec 4, 2007 | 03:53 AM
i my honda
Global Mod
Default Re: (ECX)
The gauge is actually very accurate for what it is, and that is a volt meter. You can run the LC-1 in conjunction with your autometer gauge with very accurate readings. With the LC1 software you can calibrate the controller with your gauge if it is off at all. Innovate stuff is very easy to use, I run the LC'1 along with the AEM in my car. I also have the LM1 I use to check my sensors and tune other cars.
Old Dec 4, 2007 | 06:04 AM
ECX's Avatar
ECX
* B A N N E D *
Default Re: (White Smoke)
So I can still run the Innovate setup with that gauge, the only thing I wont have is the digital display of my a/f ratio (the actual number) correct?
Old Dec 4, 2007 | 06:39 AM
i my honda
Global Mod
Default Re: (ECX)
Correct
Old Dec 4, 2007 | 06:45 AM
ECX's Avatar
ECX
* B A N N E D *
Cool, thanks man.
One more dumb question (and this is starting to turn into a tech thread instead of a "how to wire it" thread... ) but will my tuner know what the specific afr is somehow, or is that very necessary? (I'm working on a budget boost build, it's going to be tuned either with Crome or preferrably eCtune).
Old Dec 4, 2007 | 07:31 AM
B18C_EJ8's Avatar
Default Re: (ECX)
If you're running a wideband o2 sensor, don't most tuning programs (crome, neptune, Hondata) have a spot on the screen for A/F ratio?
I think I remember a spot on my Hondalogger screen for A/F ratio, but since I was only running the stock o2 sensor at the time, nothing showed up on the screen. Hence the reason why he unscrewed the stock o2 sensor & plugged in his own PLX gauge.
Old Dec 4, 2007 | 08:05 AM
i my honda
Global Mod
Default Re: (ECX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ECX &raquo;</TD></TR><TR><TD CLASS="quote">One more dumb question (and this is starting to turn into a tech thread instead of a "how to wire it" thread... ) but will my tuner know what the specific afr is somehow, or is that very necessary? (I'm working on a budget boost build, it's going to be tuned either with Crome or preferrably eCtune).
Yeah, he should know... You are gonna need to run the narrowband output of the WB (which is also going to your A/F gauge) to the stock 02 sensor input on your ECU for data logging.
Old Dec 4, 2007 | 08:48 AM
ECX's Avatar
ECX
* B A N N E D *
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C_EJ8 &raquo;</TD></TR><TR><TD CLASS="quote">Hence the reason why he unscrewed the stock o2 sensor & plugged in his own PLX gauge. </TD></TR></TABLE>
So (dumb question) you can tune with a wideband but switch back to your narrowband o2 afterwords and it still work?
Old Dec 5, 2007 | 11:47 AM
i my honda
Global Mod
Default Re: (ECX)
Yes, you should really talk to your tuner about all this as he is the one who sets up weather you run any closed loop or not.
Old Dec 6, 2007 | 04:19 AM
ECX's Avatar
ECX
* B A N N E D *
Ahhh I've got so much more to learn.
Thanks for the help man.
ECX
Lighting
Dec 3, 2007 06:03 PM
Multra Corakus
Apr 21, 2006 09:00 PM
civicnar
Feb 26, 2004 05:22 PM
TheIntegraGuy
Dec 7, 2002 12:18 PM
GOKOU
Aug 20, 2002 07:12 AM
