Does MSD cause higher EGT's and lower IDLE?
Old May 7, 2004 | 08:08 PM
VDoP-B18C1
Guest
Posts: n/a
Default Does MSD cause higher EGT's and lower IDLE?
i just got msd 6al with coil and cap installed on my b18c1 turbo app.
my cruising egts at say 80 mph used to be roughly 760 C and now they go up
to 800 C.
also, my idle use to be around 800 rpm, now it drops to about 5-600 rpm
is this normal after installing msd. can i just adjust my idle and everything will be ok?
Old May 8, 2004 | 07:46 PM
earl's Avatar
Default Re: Does MSD cause higher EGT's and lower IDLE? (VDoP-B18C1)
I think your ignition timing has become retarded. Retarding the ignition usually lowers the idle speed and raises exhaust gas temperature as there is more fuel still burning in the exhaust, thus raising the temperature.
Old May 8, 2004 | 09:35 PM
VDoP-B18C1
Guest
Posts: n/a
Default Re: Does MSD cause higher EGT's and lower IDLE? (earl)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by earl &raquo;</TD></TR><TR><TD CLASS="quote">I think your ignition timing has become retarded. Retarding the ignition usually lowers the idle speed and raises exhaust gas temperature as there is more fuel still burning in the exhaust, thus raising the temperature.</TD></TR></TABLE>
is this a bad thing? can i just readjust my idle to make it go back to normal?
will tuning fix any of this?
thanks
Old May 9, 2004 | 03:23 PM
VDoP-B18C1
Guest
Posts: n/a
Old May 9, 2004 | 03:50 PM
m R g S r's Avatar
I don't think you have anything to worry about unless the car is stalling out all the time.
Old May 9, 2004 | 04:16 PM
VDoP-B18C1
Guest
Posts: n/a
Default Re: Does MSD cause higher EGT's and lower IDLE? (m R g S r)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by m R g S r &raquo;</TD></TR><TR><TD CLASS="quote">I don't think you have anything to worry about unless the car is stalling out all the time.</TD></TR></TABLE>
when i turn on my A/C, it almost wants to stall out, but catches itself right before it stalls out.
you think i should just up the idle just a tad and maybe this will go away?
also, starting up the car requires me to hold down the gas pedal for it to turn over.
any suggestions on that?
thanks
Old May 9, 2004 | 05:14 PM
AzCivic1.6's Avatar
what your describing definitly isnt normal. i just installed a MSD digital 6 and dont have any weird idle problems, it actually got smoother.
Old May 9, 2004 | 05:41 PM
VDoP-B18C1
Guest
Posts: n/a
Default Re: Does MSD cause higher EGT's and lower IDLE? (AzCivic1.6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AzCivic1.6 &raquo;</TD></TR><TR><TD CLASS="quote">what your describing definitly isnt normal. i just installed a MSD digital 6 and dont have any weird idle problems, it actually got smoother.</TD></TR></TABLE>
did you tune it? or just install it and it got better?
what was your idle before and after msd?
how bout idle when AC is on?
Old May 9, 2004 | 06:52 PM
lgcubana's Avatar
Did U use fresh plugs & wires when U installed the MSD ? What plugs R U using ?
Old May 9, 2004 | 07:21 PM
earl's Avatar
Default Re: Does MSD cause higher EGT's and lower IDLE? (lgcubana)
try resetting your computer
Old May 10, 2004 | 12:35 AM
AzCivic1.6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VDoP-B18C1 &raquo;</TD></TR><TR><TD CLASS="quote">
how bout idle when AC is on?</TD></TR></TABLE>
i just put it on. the idle before was sometimes good, sometimes low, same w/ the ac on. now its just good.
Old May 10, 2004 | 07:49 AM
-iLLuZioN-B18C1's Avatar
thanks</TD></TR></TABLE>
another car gone bad from MSD???
Old May 19, 2004 | 04:23 PM
VDoP-B18C1
Guest
Posts: n/a
Default Re: Does MSD cause higher EGT's and lower IDLE? (-iLLuZioN-B18C1)
i forgot to mention i just regapped from .032 to .028. does this affect it?
Old May 19, 2004 | 05:59 PM
System-7's Avatar
i have the same problem. I don't mind it anymore it runs healthy after a hard run then it idles find. if your tuner is like mine they probly are overfueling at idle.
jdmark1
Mar 14, 2018 10:21 AM
JKing106
Apr 13, 2013 05:51 PM
messeduprex
Jun 24, 2004 10:13 AM
djnikko
Jan 14, 2004 03:24 AM
MintFlavored
Nov 11, 2002 12:28 PM
