ITR Head questions
Old Nov 4, 2001 | 06:38 PM
blazin's Avatar
Default ITR Head questions
Can the cam caps from a B16a Be used on a ITR head or is it true that each Honda Head has its own special caps.Reason being is that I have a ITR head that is missing the caps but I have a B16 Head that I could use the caps off of if it is possible and I you can't just get the caps from Honda.
Old Nov 4, 2001 | 06:47 PM
Katman's Avatar
Default Re: ITR Head questions (blazin)
Yes, you can reuse your B16 cam journals (caps) on the ITR head - but it would be best if you had the original ITR cam journals since it they were used and broken-in on that specific head. It's always best to have the original parts when it comes to cam journals/crank journals/rod caps/possibly the crank girdle too/anything caps....
Old Nov 4, 2001 | 06:50 PM
non-VTEC's Avatar
you should have the head and the caps sent to a machine shop to have them checked. they might not be perfect and you might ruin the head and cams if they are not line bored perfetly.
you cannot buy those separatly from the dealer........you have to buy a complete head for that.......
Old Nov 4, 2001 | 06:56 PM
1.8EG-T's Avatar
Default Re: ITR Head questions (Katman)
Not only that but like the crank journals they are line bored, the smallest deviance could mean bad news for a crank or cam.
insaneconceptz
May 29, 2010 05:10 PM
gutted-dx
Dec 23, 2008 07:26 PM
crispy93
Mar 8, 2007 07:17 PM
rorik
Jan 20, 2006 08:54 PM
hybridmiklo
Sep 18, 2005 08:09 PM
