where to get this?
i dont know but i hope someone finds out that would make my life alot easier with that im having a problem because of a loose connection.
Why would you need it?
I installed my VAFC yesterday and it only took me 30 minutes start to finish...(my first install)
Soldering is not that hard to learn if that's the concern. Just go buy some wire and practice practice practice.
There is a lot of good info on soldering, just search around.
edit:: sorry I didn't answer your original question.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by koreanwilcox »</TD></TR><TR><TD CLASS="quote">Why would you need it?
see i was thinking of get a vafc from my friend for $100 w/o the second half of the harness..if i can get this obd2 to obd2 w/ vafc harness for under $100 that would be good.
</TD></TR></TABLE>see i was thinking of get a vafc from my friend for $100 w/o the second half of the harness..if i can get this obd2 to obd2 w/ vafc harness for under $100 that would be good.
y would I really want to cut and splice into my factory wiring harness? I know i dont want to...I guess people that dont give a **** and trash out their cars do that
I thought that was for you to just plug into your ecu so you dont have to cut anything i didnt know that was a conv. pc. if it is a plug and play unit where can we buy them cause im going to be paying someone to put to solder my vafc in and i rather just plug it up and go.
so is this a conv. kit or is it just to make hooking up your vafc easy? cause i have a obd 1 and i just want an easy install so i dont have to hack and solder my wires.
this is a conversion harness from different obd codes w/ a seperate harness wired in for a vafc.
different places sells them i know there are a few people on here and if it serves me correctly
http://www.jhpusa.com no longer has them b/c Katman has worked there or something and he now has his own website and i know that he is also a member on here..
Hard2Find
Jun 8, 2002 08:56 PM
ImprtTuner88
Dec 5, 2001 07:55 AM
