Installing Apex VAFC tonight....any suggestion and pointers?
Global Moderator
Re: Installing Apex VAFC tonight....any suggestion and pointers? (Hard2Find)
Solder it and remove the ECU when soldering, to eliminate any risk of overheating the board.
follow the directions and make sure that you splice into the correct wire.. make a good connection using soldier and electrical tape.. and then make sure the vafc is setup correctly before you start or run the car.. its really not that hard to do at all, i got mine installed in less than 1 hour
Re: Installing Apex VAFC tonight....any suggestion and pointers? (Reid)
http://www.diabloautosports.com/prod...44b4aad5c3d065
Just buy one of these and use it then you don't have to solder or mess up any of your own wiring.
Just plug and play. This is what I plan on getting so that it will save me some time and probably headache.
Good luck to you and may the force be with you.
Re: Installing Apex VAFC tonight....any suggestion and pointers? (EGB18hatch)
thanks people!
VAFC is INSTALLED! no CEL...
but only thing i notice is that i had idle surge for short while....but then its ok..
