quick vafc install question
Old Dec 12, 2003 | 09:46 PM
216.226.142.95:27016's Avatar
Default quick vafc install question
i bought a vafc fromt someone and this is the harness that i got
the question is, the istructions that i got from apex said something about female/male connectors. i see the ones from the vafc side, am i missing the one for the ecu side?
last, what do i do with the blue wire for the VTM signal. is it a straight tap into the wire?
Old Dec 12, 2003 | 09:59 PM
Default Re: quick vafc install question (216.226.142.95:27016)
come on, im itching to install this right now!
Old Dec 12, 2003 | 10:21 PM
anyone awake?
Old Dec 12, 2003 | 10:25 PM
XSSIVE's Avatar
i'm not sure on the vtm...but i can tell you this, yes you are missing some of the the famale and male connectors b/c they would attach to the factory ecu wires to let you plug those vafc wires into them. anyway, i never trust those things on wires as important as the ecu, you are better off soldering every single wire, don't bother with crimping and whatnot, it may take a few minutes longer but it will be a better and stronger connection you wont have to worry about...better off safe than sorry. hope that helps a bit...but if you want to crimp them, you can get the female and male connectors to match those at pepboys, radio shack or home depot.
-Mike
Old Dec 12, 2003 | 10:52 PM
Default Re: quick vafc install question (XSSIVE)
i did ended up cutting them. i got all the wires ready to be soldered, i figure out the blue wire later on.
Old Dec 13, 2003 | 07:17 AM
2001teggsr's Avatar
Go buy some new male/female connectors I wouldnt recommmend soldering them the wires are so small the heat will travel fast to the ecu could mess something up...the vtm signal the blue wire was left off of certain cars depending on year and motor...
Old Dec 13, 2003 | 07:35 AM
XSSIVE's Avatar
Default Re: quick vafc install question (2001teggsr)
don't worry about heat traveling to the ecu b/c the battery should be unhooked and the ecu should be unpluged while doing this install. It's safer and makes the wires easier to get to.
-Mike
Old Dec 13, 2003 | 11:04 AM
its installe but i have yet to turn the car on. i cut the vtm signal from the engine harness and have it directly connected to the vafc.
Old Dec 13, 2003 | 11:22 AM
fergy016's Avatar
which wire is the vtm wire?
Old Dec 13, 2003 | 12:50 PM
Default Re: quick vafc install question (fergy016)
3rd plug on the ecu, top right. its a blue wire
like here
http://www.ff-squad.com/tech/w...2.jpg
its reffered to as the vtec pressure swtich
EJ1 wilcox
Jun 7, 2004 09:33 AM
darkjedi022
Feb 5, 2004 05:52 AM
LSTEG96
Nov 6, 2003 09:14 PM
1hotintegra
Aug 4, 2003 09:33 AM
BRICKHEAD
Dec 2, 2002 06:23 AM
