Please post good mods for increasing Throttle response.
Old Nov 4, 2001 | 02:02 PM
1GreyTeg's Avatar
Default Please post good mods for increasing Throttle response.
I have monkeyed with my intake "comptech," at the Auto-X and appreciate the increased Throttle response when the "icebox" has it's top removed.
But, I also notice some TQ loss when it IS off.
So I am interested in keeping my intake operating as a whole But, I am also interested in increasing Throttle response for my everyday and or track use.
Any suggestions?
Bigger bore aftermarket TB? Or Overbore the TB? OK by how much? And by who? Or which company?
Other ideas?
Thanks guys,
A.
Old Nov 4, 2001 | 03:12 PM
Kamin's Avatar
Default Re: Please post good mods for increasing Throttle response. (1GreyTeg)
flywheel
Old Nov 4, 2001 | 04:21 PM
lazyvietboi's Avatar
Default Re: Please post good mods for increasing Throttle response. (rawdigga)
tighten the throttle cable remove any slack....
Old Nov 4, 2001 | 04:53 PM
fixhondas's Avatar
Default Re: Please post good mods for increasing Throttle response. (lazyvietboi)
Tighten your throttle cable and your engine will not idle properly. There should be some slack in it. What part of the powerband are you looking to increase response?
Old Nov 4, 2001 | 05:59 PM
Dr Pooface's Avatar
Default Re: Please post good mods for increasing Throttle response. (fixhondas)
I took the slack out of mine and it idles fine.
Old Nov 4, 2001 | 07:20 PM
fixhondas's Avatar
Default Re: Please post good mods for increasing Throttle response. (Dr Pooface)
depending on how tight you make it and depending on the temperature the throttle cable being too tight can cause a non-closed throttle postion and this can cause a surging idle problem, particularly on decel. I see this all the time. Taking out the recommended slack will net you nothing in performance gains.
Old Nov 4, 2001 | 07:27 PM
InfamousRS's Avatar
I removed the slack out of my throttle cable, there is hardley any slack left in it. I love the way it feels! after all of my friends felt my throttle, they did it to their cars too.
Old Nov 6, 2001 | 05:30 PM
speedworks's Avatar
Default Re: Please post good mods for increasing Throttle response. (BLK94RS)
a big fat hair drier increases throttle responce dramatically.call turbonetics
Old Nov 6, 2001 | 06:29 PM
martini's Avatar
Default Re: Please post good mods for increasing Throttle response. (speedworks)
lightweight flywheel helps throttle response quite a bit.
and, aftermarket intake tubes with smooth intake tubes help speed the intake charge, and will help with throttle response.
I do agree that removing any slack in your idle will help, assuming you don't remove too much, it shouldn't affect your idle at all.
Old Nov 6, 2001 | 08:45 PM
dplatt's Avatar
An overbored TB helps with throttle response. RC Engineering does great work for $225.
Old Nov 7, 2001 | 01:35 AM
buh_buh's Avatar
Default Re: Please post good mods for increasing Throttle response. (dplatt)
more power normally results in better throttle response
Old Nov 7, 2001 | 04:34 AM
kkim's Avatar
try advancing timing to 18d btdc or at least check where your timing is. I've found them off from the factory in the past. stock is 16d +/-2.
Old Nov 7, 2001 | 03:55 PM
Max GSR's Avatar
Exactly!
JDMarkLangston
Apr 25, 2013 07:35 PM
theresyourproblem
Oct 4, 2007 09:28 AM
damn_import_culture
Jul 13, 2006 08:06 AM
Cute EK
Nov 15, 2005 06:18 PM
sslude
Aug 29, 2003 04:53 PM
