how do i adjust the throttle cable??
Old Jan 20, 2003 | 07:44 AM
sslude's Avatar
Default how do i adjust the throttle cable??
i want to make the throttle cable alittle tighter. oculd some one give me pictures (if you can) and step-by-step instruction on how? thanks
Old Jan 20, 2003 | 11:30 AM
sslude's Avatar
Default Re: how do i adjust the throttle cable?? (sslude)
anyone?
Old Jan 20, 2003 | 11:37 AM
optikal_blitz's Avatar
yeah - bump for a good question.
Old Jan 20, 2003 | 11:42 AM
Sticky Tires's Avatar
* B A N N E D *
Default Re: how do i adjust the throttle cable?? (NatakuBlitz)
it's kinda like tightening the brakes on a bicycle. just untighten the screw and tighten up the slack on the throttle cable and retighten the screw. it ain't hard. you best be easy on the clutch after or catch a case.
Old Jan 20, 2003 | 12:05 PM
KW2000's Avatar
Default Re: how do i adjust the throttle cable?? (StickyTires)
jsut don't go to much on the throttle cable....hehe you'll soudn like u are reving your engine at idle
Old Jan 20, 2003 | 01:31 PM
sslude's Avatar
Default Re: how do i adjust the throttle cable?? (KW93LUDE)
okay, there is the throttle cable, then are 2 bolts, one closer to the TB and one farther away, which one do i loosen/tighten? is there anything i should be careful of while doing it besides tighten it too much?
Old Jan 20, 2003 | 01:45 PM
TimeRacer's Avatar
If you're really not sure which one you should tighten I wouldn't recommend you working on it, it's very straight forward... think about it, you're picking up the slack from the mounting point to the throttle body. If you still can't get it, don't work on it, ask someone who knows to show you how.
[Modified by TimeRacer, 2:46 PM 1/20/2003]
Old Jan 20, 2003 | 02:23 PM
* B A N N E D *
Default Re: how do i adjust the throttle cable?? (TimeRacer)
just play around with it, you'll see which one will loosen/tighten the cable.
Old Jan 20, 2003 | 03:52 PM
sslude's Avatar
well, just tell me if its the one closer to the throttle body or the on farther. the 2 bolts are close together but something separates them. if i loosen it do i have to hold on to the cable. one last question, when i turn the bolt, do i pull the cable or does the cable tighten WHEN i turn the bolt? thanks
Old Jan 20, 2003 | 06:13 PM
* B A N N E D *
i think you have to loosen both and tighten the cable yourself if i remember it correctly, but damn man just play with it you ain't gonna mess **** up unless you got the engine runnin.
Old Jan 20, 2003 | 06:14 PM
* B A N N E D *
i think you have to loosen both and tighten the cable yourself if i remember it correctly, but damn man just play with it you ain't gonna mess **** up unless you got the engine runnin. you'll prolly hurt yourself
Old Jan 20, 2003 | 07:14 PM
TimeRacer's Avatar
I'm sorry, but good lord! The end of the sheathed part of the throttle cable is threaded and this is where your two bolts thread. When looking at the position of the throttle cable you'll see the first retainer bolt, then the mount, and then another retainer bolt. The mount is sandwiched between the two retainer bolts, which in turn are threaded on the end of the sheath. All you need to do is loosen one of the bolts to relieve the tension, and adjust the mounting point accordingly depending on your situation. If you STILL don't understand, don't touch it. I'm truly scared that #1 you won't attach it correctly back in and have it fall off it's mount (possibly leading to a crash due to loss of power), or #2 have it on so tight that you'll redline the engine on startup when it's in neutrual and blow the engine. If you really don't understand, don't mess with it unless you can afford to fix it.
Old Jan 22, 2003 | 12:14 PM
* B A N N E D *
if you STILL don't understand, don't touch it. I'm truly scared that #1 you won't attach it correctly back in and have it fall off it's mount (possibly leading to a crash due to loss of power), or #2 have it on so tight that you'll redline the engine on startup when it's in neutrual and blow the engine. If you really don't understand, don't mess with it unless you can afford to fix it.
right ****** on the point.
Old Jan 22, 2003 | 12:38 PM
stockludesi's Avatar
w3rd thank you for clearing that up, i hope he learns........also......in time if you're afraid of ruining your car and you don't have prior knowledge of what you're doing, or know how to turn a wrench....lol.....then hand your car over to someone else who knows how to modify a car.............not trying to be mean at all, sorry if i came off like an ***.
Old Aug 29, 2003 | 10:54 AM
rjr162's Avatar
Default Re: how do i adjust the throttle cable?? (stockludesi)
you're not really going to adjust much at all unless your cable is truely loose. There's a rubber "Spring" on the top of the gas peddle the cable goes in so when you his about the gas peddle about 85% of the way to the floor you're at WOT anyhow.. the rest of the peddle pushing only squashs the rubber section
Old Aug 29, 2003 | 03:19 PM
* B A N N E D *
Default Re: how do i adjust the throttle cable?? (rjr162)
you followed the link i posted in the other thread and brought a back from the dead thread.
Old Aug 29, 2003 | 04:53 PM
Default Re: how do i adjust the throttle cable?? (Sticky Tires)
man, so many threads up from the archives lately..
boostedteg1203
Jan 14, 2010 01:17 AM
NAallthewayEM1
12
Aug 1, 2009 08:41 PM
theresyourproblem
Oct 4, 2007 09:28 AM
blunty
Apr 22, 2002 07:51 AM
2k1TypeR0610
Oct 25, 2001 03:46 PM
