b18b turbo what cams should i run
Old May 3, 2004 | 03:27 PM
civichbb18's Avatar
Default b18b turbo what cams should i run
i have a ls turbo with dsm injectors and safc and a flywheel i was wondering witch cams would be best and cam gears and what to set cam gears to for most power in 1/4
Old May 3, 2004 | 03:37 PM
CaptainMorgan's Avatar
Default Re: b18b turbo what cams should i run (civichbb18)
A vtec head will flow much better then a built ls head. So don't waste your money on cams for the LS.
Old May 3, 2004 | 04:09 PM
v-6 hatch's Avatar
Default Re: b18b turbo what cams should i run (CaptainMorgan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CaptainMorgan &raquo;</TD></TR><TR><TD CLASS="quote">A vtec head will flow much better then a built ls head. So don't waste your money on cams for the LS.</TD></TR></TABLE> thats not quite true. perhaps a stock ls head but a ported ls head will flow just as well as an v-tec head ported so, its a tough call
Old May 3, 2004 | 04:45 PM
AROD's Avatar
Default Re: b18b turbo what cams should i run (v-6 hatch)
try gudes bullfrog "gorrila turbo" cams. 430 lift and 259 duration good for turbo . redline 9,000k shift @ 8-8500k
Old May 3, 2004 | 04:50 PM
Blaze45's Avatar
Brrraaaap!
Default Re: b18b turbo what cams should i run (1.83Tc)
Contact rocket, he has some sweet cams for the LS/B20 motor. They are awsome and very reasonably priced.
Blaze
Old May 3, 2004 | 05:20 PM
Hoosier Daddy's Avatar
Default Re: b18b turbo what cams should i run (Blaze45)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blaze45 &raquo;</TD></TR><TR><TD CLASS="quote">Contact rocket, he has some sweet cams for the LS/B20 motor. They are awsome and very reasonably priced.
Blaze</TD></TR></TABLE>
http://www.m24x.com I have the L21 cams. Great cams
Old May 3, 2004 | 05:23 PM
JDM EJ1 95's Avatar
i was wondering the same thing... but what is all your thoughts on the skunk 2 turbo cams?
Old May 3, 2004 | 05:26 PM
calib17a's Avatar
Just got my CTR intake cam and will be using the stock b17a exaust cam.
Old May 3, 2004 | 05:40 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by v-6 hatch &raquo;</TD></TR><TR><TD CLASS="quote"> thats not quite true. perhaps a stock ls head but a ported ls head will flow just as well as an v-tec head ported so, its a tough call</TD></TR></TABLE>
I have a built LS head. crower turbo cams, inline 4 valves, crower duel springs, and its also ported. I start losing power at 6.2 rpm. If you look at some of the big HP LS's, they all lose power. If they don't lose it at 6000 rpm they for sure will at 6.500 form 6.2-7.2 i lose 70 whp and 100 tq. Xrtdac on this site also have the same problem. power lost at 6000 rpm, he lost 30 whp and 100 tq. The reason is, becasue the ls head can't flow that much air in, at higher rpm. Instead of getting cams, valves, valve springs, camgears, and porting done. By that time he could of gotten a vtec head and be done.
I think if you plan on making something like 300 whp, then thats fine. but anything over that, go LS/vtec
Old Dec 17, 2004 | 03:42 AM
J-Spec EG's Avatar
I think if you plan on making something like 300 whp, then thats fine. but anything over that, go LS/vtec</TD></TR></TABLE>
That cant be all that true can it?
Old Dec 17, 2004 | 04:10 AM
non-VTEC's Avatar
if your loosing power over 6000rpm then you have some other problems.
my non-vtec head setup made peak power at 7400rpm and still pulled great to 8000+.........
best non-vtec cams Crower hands down......
Old Jun 1, 2006 | 05:38 AM
PhatBoy5015's Avatar
Default Re: b18b turbo what cams should i run (non-VTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by non-VTEC &raquo;</TD></TR><TR><TD CLASS="quote">if your loosing power over 6000rpm then you have some other problems.
best non-vtec cams Crower hands down......</TD></TR></TABLE>
Yeah, but I have seen a lot of people who had broken Crower cams in half and messed up the whole head. I wouldn't take a chance on cams.
What other cams are good for power and very reliable?
Snailor Built
Sep 15, 2009 08:34 AM
ELPITUDO
Jul 19, 2007 01:33 PM
95GSRTT
Sep 8, 2004 01:22 PM
importlegions
20
Jun 25, 2004 10:13 AM
specie
Feb 6, 2004 02:04 PM
