How to "tighten slack in steering"
My steeting seems to have slack in it. Like its not calibrated right, seems like it feels real light, and has a lot of play in it. Any way to fix this? Just the latest of my suspesion problems
thanks
thanks
check your bearing and steering play, most likely it will be the inner and/or outer tie-rods, lift up the front end with the tires off the ground and shake the wheel up and down to check for bearing play, shake it side to side for tie rod end play, have someone shake it while you check to see/feel any movement
Is this your problem? http://integra.vtec.net/tips/steeringadjustment.html
Next time I have my car up on stands (thursday to instal my KYB AGXes)I might give it a try. My steering seems a little sloppy compaired to my friends 96.
[Modified by BLK94RS, 4:43 AM 11/5/2001]
hummm.. car is on jack stands as we speak.... hummmmm, if only I had time... and someone else on here has already done this without any problems
