getting 370 cc injectors and vafc good idea?
Old May 2, 2004 | 09:01 AM
brandond's Avatar
B A N N E D
Default getting 370 cc injectors and vafc good idea?
hey wuts up guys im finally getting my turbo setup this week it consists of t4 turbo manifold, turbo timer, bigggg front mount intercooler, hks wastegate and turbo xs BOV........i just have one question this week i bought rc 370 cc injectors and i got my apexi v-afc and a manual boost controller i picked up.........i should b fine on fuel if i only want to boost 6-8 psi for now correct...i was told it would b fine even better than a fmu
Old May 2, 2004 | 09:11 AM
Mag00n's Avatar
Default Re: getting 370 cc injectors and vafc good idea? (brandond)
Not sure what your question is? VAFC is not the BEST fuel management, but for that setup and 6-8psi it will be fine. There IS better out there, but that's up to you.
Old May 2, 2004 | 09:32 AM
brandond's Avatar
B A N N E D
Default Re: getting 370 cc injectors and vafc good idea? (SICKSOLVTEC-T)
yeah buddy i went to bristol dyno and i talked to this guy i forgot his name and he was saying if i run that apex vafc and 370 cc injectors i should b a ok on 6-8psi all day so im gonna run that until i get some dough for the 550's and hondata
Old May 2, 2004 | 09:34 AM
b16ahybrid's Avatar
Make sure you do some tuning on a dyno when you first put it all together. You may need to play with your fuel pressure a little.
Old May 2, 2004 | 09:39 AM
brandond's Avatar
B A N N E D
Default Re: getting 370 cc injectors and vafc good idea? (b16ahybrid)
yeah i got one more question when i do put it all together this week is it safe to drive it to the dyno on like 6psi but try not to step on it on the way there and then tune it
Old May 2, 2004 | 09:43 AM
b16ahybrid's Avatar
Yeah I would recomend leaving the stock injectors in and driving (without boosting) to the tuner. Thats what I had to do.
stockb18c
Oct 24, 2006 04:55 PM
JadecrewGSR
Apr 26, 2005 08:28 PM
b18cya
Feb 24, 2003 07:55 PM
CalvitoSol
Jun 17, 2002 09:13 PM
greyzone
Dec 14, 2001 09:54 PM
