FAULTY IAC???
Old May 1, 2004 | 05:46 PM
JO3's Avatar
JO3
Default FAULTY IAC???
hey ppl..
i've had this problem on my car for at least 2 weeks now and just need some advice from u all...
it's been hunting (sometimes) when i drive..like i'll be cruising nicely and the car will just start reving up and down by itself...
this hunting problem also happens when my car is not in gear with my legs on the accelerator.....
and sometimes...the car will idle between 1000-1500 rpm...
this is what i've done to help fix the problem so far:
1. cleaned the IAC ( was ok for like 3 days)
2. re-set the ecu and got it checked (no errors shown)
3. checked for vacuum leak (nothing found)
4. checked if any of the fuses behind the inlet manifold has been switched(they're in the right place)
5. cleaned the throttle body(include adjusting TPS) and injectors (didnt help)
i've done almost everything but it still happens...
this is my question:
whenever the car idle's high or starts hunting...
the only way to solve this is to plug out the back up fuse for the IAC for 10sec and then put it back....(i was told this re-set the idle)
and most of the time this works..not for long tho...
so could i safely assume that the IAC is faulty?...
or the fact that by doing that and it helps means that the IAC is in working condition?..
i just wanna get some advice from u guys cos i dont wanna spend money getting an IAC just to find out the problem is somewhere else..
so if anyone could tell me if the IAC is spoil o not..that'd be good..
thanks ppl..
JOE
Old May 2, 2004 | 12:24 AM
DohC-VTeC801's Avatar
Default Re: FAULTY IAC??? (JO3)
i had a problem almost like yours... Mine had air bubbles in the coolent. I just had to bleed it out.
Old May 3, 2004 | 02:34 PM
frenchy's Avatar
Default Re: FAULTY IAC??? (DohC-VTeC801)
did that actually work?
Old May 3, 2004 | 09:02 PM
Default Re: FAULTY IAC??? (frenchy)
yea bleedin the coolent worked for me
Old May 4, 2004 | 07:55 AM
frenchy's Avatar
well i guess if honda bothered putting a bleeder valve on the coolant lines it must do something
Old May 11, 2004 | 06:14 AM
TurboBumblBee's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by frenchy &raquo;</TD></TR><TR><TD CLASS="quote">well i guess if honda bothered putting a bleeder valve on the coolant lines it must do something</TD></TR></TABLE>
there isnt a bleeder valve on my b18c1 but im having a similar problem w/ the car and recently switched out the radiator there is a possibility its this, air getting the iacv and other parts of the motor can cause it to do this..
Old May 11, 2004 | 05:59 PM
JO3's Avatar
JO3
well..i just got my iacv changed yesterday..
so i'll see in a few days if the problems gone..
praying hard it will..
Old May 12, 2004 | 04:51 AM
JO3's Avatar
JO3
Default Re: (JO3)
hey ppl..
just got the iacv replaced...brand new one..
but problem still there...
it's like the car is misses a heart beat(like one of the members here called it)..
and then it started idling at 1100rpm...
what should i do now?...
got the distributor checked..everything seems good....
advise needed..
thanks..
Old May 12, 2004 | 06:55 AM
MENACE's Avatar
Default Re: (JO3)
Yeah mine does this to. Sometimes the motor will miss at Idle or it will rev up to 1500 and drop down to 1000. Ive bleed the coolent and it didn't help.
Im thinking mine has something to do with the EGR not being hooked up and alot of carbon in the intake manifold. I let you guys know when i clean the intake and block off the EGR.
Oh yeah the motor is a JDM D15b Vtec (econo) &lt;--- that sucked.
Old May 14, 2004 | 05:28 PM
MENACE's Avatar
Default Re: (MENACE)
Ok well today I removed My Iac It was Clean. I Also Put a blocking plate on the EGR valve since its not hooked up. That seemed to take care of the problem the car no longer Idles back and forth. But i still have a miss so im thinking that was another problem not associated with the Hunting Idle. As far as your setup go's i would look for cracked hoses or anthing that could cuz a vacum leak. Thats basically what the EGR valve was doing on my car since it wasn't hooked up it was like a small vacum leak. Hope this helps.
dth0ng69
Oct 8, 2009 12:48 PM
PhilMac
Jun 17, 2007 02:09 PM
Kirk@SyndromeAuto
Jan 31, 2007 08:45 PM
homeskillet
Jan 13, 2005 05:04 PM
BDiddy
Jan 10, 2003 06:50 AM
