tourque dampner
Old May 1, 2004 | 02:56 PM
thugfolife2's Avatar
Default tourque dampner
what does a tourque dampner do?
Old May 1, 2004 | 03:00 PM
Kal's Avatar
Kal
Default Re: tourque dampner (thugfolife2)
prevents the engine from moving too much inbetween shifts and launching. helps with wheel hop
Old May 1, 2004 | 03:20 PM
TrueZen's Avatar
Default Re: tourque dampner (Kal)
Would also recommend motor mounts, do the same as the torque dampner and are much less expensive(if you install yourself). Did a redline 1-2 shift today and barely chirped the tires going into second, stock tires stuck like a champ.
Old May 2, 2004 | 06:38 AM
ITR_1211's Avatar
elimates flex between your engine. It also helps cure shifting as there is not much flex or movement on the tranny/engine.
Old May 2, 2004 | 01:12 PM
RSX8600's Avatar
Default Re: tourque dampner (Darryl Musashi)
I had both, mm are bang for the buck.
Old May 2, 2004 | 01:51 PM
TrueZen's Avatar
Default Re: tourque dampner (RSX8600)
Did you use them both at the same time? I have just the mm's right now(boy that install was fun), but may be looking at a torque dampner in the future. If you used them at the same time, what was your impression of the setup?
Old May 2, 2004 | 02:45 PM
RSX8600's Avatar
Default Re: tourque dampner (TrueZen)
No i had them on two diff. rsx's. First one i had mm and the vibration got crazier the longer they were in they did good for how much they cost. Now i got the torque dampner i like it way better no vibration at all and it holds just as good as the mm did.
Old May 2, 2004 | 07:34 PM
how much do mm's cost around for ep3
Old May 2, 2004 | 08:27 PM
TrueZen's Avatar
You can find the Energy Suspension motor mounts for around $25-30.
Old May 2, 2004 | 08:28 PM
TrueZen's Avatar
Check out: http://www.energysuspension.com
Old May 4, 2004 | 06:16 PM
PostMASTER-S27's Avatar
Put both the ES and Dampanner It's the best way to go....
corsport
Performance
10
Jul 21, 2011 09:40 AM
RICO_
Honda Civic (2006 - 2015)
58
May 29, 2009 11:51 AM
moosta936
Oct 10, 2008 09:23 PM
FOOLS_Si
Jun 15, 2007 02:47 PM
futomame
Honda S2000
Oct 13, 2006 02:25 PM
