Ignition
Old Apr 27, 2004 | 03:33 PM
drinkydoob16's Avatar
Default Ignition
Hi Everyone
Whats the best upgrade for my ignition. I have a 92 JDM Civic SiR stock (Intake and exhaust) i want to upgrade the ignition system. Whats the best? And whats the difference between MSD 6A and MSD SCI?
Thanks
Old Apr 27, 2004 | 03:48 PM
_BEN_'s Avatar
Default Re: Ignition (drinkydoob16)
The stock honda ignition system is more than adequate until you are making big hp numbers like 400 plus.
Old Apr 27, 2004 | 03:49 PM
Yeung's Avatar
Default Re: Ignition (_BEN_)
what does an ignition upgrade do for you?
Old Apr 27, 2004 | 03:52 PM
rodrez.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by _BEN_ &raquo;</TD></TR><TR><TD CLASS="quote">The stock honda ignition system is more than adequate until you are making big hp numbers like 400 plus. </TD></TR></TABLE>
Old Apr 27, 2004 | 03:54 PM
_BEN_'s Avatar
Default Re: Ignition (rodrez)
Also might i add...
or also if you are revving above 12k
Old Apr 27, 2004 | 04:59 PM
Mr Hammond's Avatar
a/k/a Jomo
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drinkydoob16 &raquo;</TD></TR><TR><TD CLASS="quote">Hi Everyone
Thanks </TD></TR></TABLE>
Untill you need an MSD Digital 7 Plus, don't touch it.
Old Apr 27, 2004 | 05:01 PM
Hi Ben....I wanted to do the ignition ...but u say stock ignition is ok.......so do u think a VAFC from APEXi would be a good upgrade to do?
Old Apr 27, 2004 | 05:26 PM
rodrez.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drinkydoob16 &raquo;</TD></TR><TR><TD CLASS="quote">Hi Ben....I wanted to do the ignition ...but u say stock ignition is ok.......so do u think a VAFC from APEXi would be a good upgrade to do?</TD></TR></TABLE>
VAFC and a dyno session could smooth out your curve, but you'd be better off finishing the bolt-ons, with a header.
Old Apr 27, 2004 | 09:54 PM
Thanks everyone...also what if i change the transmission......will i also need to change the ECU?
Thanks very much for all your help
coupon
Feb 16, 2005 01:12 PM
Jockobo
Jun 30, 2004 01:46 PM
g2turbo
Aug 30, 2003 10:35 AM
SpdFrk
Aug 9, 2003 08:32 AM
tegrakid
Jul 23, 2003 11:03 PM
