gsr brakes on ek
Old Apr 27, 2004 | 10:32 AM
RC211V's Avatar
Default gsr brakes on ek
if i get the rotors and calipers for a gsr are there any other parts i need for the brake swap? im only interested in the front swap for now. because the lug patern for the ek and dc are both 4-100. the bracket that the calipers mount to..... will i need gsr bracktets or will the ek ones fit the gsr's? anything else come to mind when i do the swap? let me know.
Old Apr 27, 2004 | 10:38 AM
nahledge 7's Avatar
are u planning on putting these on a cx? is so im pretty sure ur gonna need the entire front knuckle assemble.
check import auto salvage for some good prices on brake swaps.
Old Apr 27, 2004 | 09:11 PM
RC211V's Avatar
Default Re: (nahledge 7)
yes they are going on a cx hatch. is import auto salvage a .com or are you saying to check my local import auto salvage yard?
Old Apr 27, 2004 | 09:29 PM
GetawayInMoscow's Avatar
Default Re: (Civic CX Hatch)
http://www.importautosalvage.com
Old Apr 27, 2004 | 09:39 PM
EG-B20vtec's Avatar
Change the entire front hub assembly in order to use the GSR front brakes.
Also, add the GSR lower control arms and
Front sway bar while your at it!
Feels tight on a CX trust me.
I did it!
Oh and get the rear trailing arm assembly with rear discs while you're at it.
Use the GSR/LS/RS master cylinder if you want mad tight braking yo!
Old Apr 27, 2004 | 09:48 PM
nahledge 7's Avatar
i got a 99 si master cylinder. $45 shipped
race4fox
Mar 22, 2009 04:00 PM
ieatrice
May 20, 2007 07:11 PM
Eaglekper0046
Feb 7, 2007 09:35 AM
lowgman
Jan 16, 2005 07:19 PM
