Wire up your siren to a button?
Old Apr 26, 2004 | 10:18 PM
GotGSR's Avatar
Default Wire up your siren to a button?
Anyone done this before? My goal is to have a little button inside the car, that makes the siren chirp. Just to get someones attention for instance using something less than the horn.
I've seen it before, but am curious how to do it myself!
Old Apr 26, 2004 | 11:04 PM
LSP's Avatar
LSP
Default Re: Wire up your siren to a button? (GotGSR)
if your siren is positive trigger, just hook up a button with one of the wire connected to positive, and the other wire connected to the positive wire on the siren. You can also use a relay but thats a bit more involved. If i lost you, sorry. haha
Old Apr 27, 2004 | 08:42 PM
GotGSR's Avatar
hmmm kinda confused... any more detail would be great! Thanks for the reply though.
Old Apr 28, 2004 | 12:55 AM
Trixiem's Avatar
hook one side of the momentary switch(2pole) to a power line, other side to the pos lead of the siren. push the button and enjoy
-kenny
Old Apr 28, 2004 | 07:26 AM
o_Rage_o's Avatar
Default Re: Wire up your siren to a button? (Trixiem)
If your hooking up near the center console, tap the power near your Cig Lighter to one end of the switch, and run the other wire to where the siren wires enter your car to the alarm (check kickpanel if that's where your alarm is)..
I would prob Wire a Diode to the wire as well, so that you don't Input 12v to your Alarm's 12v siren output and possibly blow it.
[EDIT] turned the diagram from text to a jpeg....sorry..
In that diagram, the current would only be allowed to flow up from the alarm to the siren, and not down to the alarm output from the switch. The diode you need would be a 4001 series 1 Amp Diode (1N4001/L) and you can get it from any electronics store for about 25 cents.
I'm not sure about the full necessity of the diode, because the alarm might have built in diodes to prevent your circuit from blowing when +12v is placed at an output, but IMHO the diode should be the safe way to go. We'll see when some of the more expirenced installers on this forum do their posts in reply to this.
Take Care,
Shane.
Old Apr 28, 2004 | 07:59 AM
audioroach's Avatar
Default Re: Wire up your siren to a button? (o_Rage_o)
That way rage has it...it should work.
One thing though...Check your local moto vehicle
code...by adding this device you could get the
attention of local law enforcement.
Old May 11, 2004 | 09:39 PM
GotGSR's Avatar
Default Re: Wire up your siren to a button? (audioroach)
sounds good...any last comments before i take a knife to my wiring?
Old May 12, 2004 | 12:36 AM
o_Rage_o's Avatar
yea, use a cutting plier
Good luck!
-Shane
chillerice
Audio / Security / Video
Apr 30, 2013 07:54 PM
m.glisson003
11
Oct 11, 2011 11:34 AM
Dub C
Sep 13, 2008 11:49 AM
crystalblue99lude
Aug 2, 2005 07:45 PM
SleekBlkPrelude
Mar 26, 2003 12:09 PM
