Installing LED Scanner (VARAD)
Old Mar 25, 2003 | 02:56 PM
SleekBlkPrelude's Avatar
Default Installing LED Scanner (VARAD)
I bought a VARAD GOTHIC SCANNER about 1 year ago, and have yet to put it in... i have an alarm system to work with it, however i don't know how to install it... it seems pretty easy, one wire to the + and one wire to the -, and one wire to ground it... but, where do i find the place with the wires to connect them to???
can i connect it to the lil 1 red led light in my steering column?
Directions please! and pics if u have them... thanks
Old Mar 25, 2003 | 05:55 PM
H22A EG's Avatar
Default Re: Installing LED Scanner (SleekBlkPrelude)
what kind of alarm do you have?
Old Mar 25, 2003 | 08:41 PM
Default Re: Installing LED Scanner (H22A EG)
i have 3 channel clifford w/ motion sensor... no one can do **** to my car without me knowing bout it... but that's besides the point... because this led scanner can be put on any car with or without alarm...
if u knw how to install this, please tell me.
Old Mar 26, 2003 | 07:14 AM
nOOber's Avatar
Wire the 2 wires at your ign switch.
wire the B+ to 12 Volts contant (with a fuse of course).
wire the ground wire to your ignition or accessory wire (+).
this way, it won't be on while you're driving around, but when you take the key out it will turn on.
Old Mar 26, 2003 | 10:05 AM
desync's Avatar
Default Re: Installing LED Scanner (nOOber)
Blah, + should get 12 volts (fused), - should go to ground, and the 3rd wire should be yellow or blue, and switched 12 volts, or hooks in to the led output of your alarm (might not work if your alarm sends pulsed power to make the led flash)
Old Mar 26, 2003 | 12:09 PM
Default Re: Installing LED Scanner (desync)
yea i think there is not enough power in the lil led flash to power the scanner... but your instructions are cluelss to me... i'm not good with Car RElated Elcectronics...
Dub C
Audio / Security / Video
Sep 13, 2008 11:49 AM
crystalblue99lude
Aug 2, 2005 07:45 PM
GotGSR
May 12, 2004 12:36 AM
ScottEK
Jul 23, 2003 10:06 AM
TurBoXBirD16
Feb 26, 2002 03:12 AM
