Tapping Oil Line from head?? does it work? enough oil?
i was wondering if there is enough flow to keep the turbo cool/lubricated? i saw a turbo'd LS a few days ago that tapped the hole right next/above the water temp sensor for oil. does this reduce the amount of oil flowing to the head and if it does, wouldn't that be bad once you're in the higher rpms? most of the cars i've seen turbo'd tap oil where the oil pressure sensor is.
Modified by shermanyang at 11:52 PM 4/26/2004
well think of it like this.. the flow of anything where ever is more freely it will follow its path.. just like E cutouts for exhaust.. so i would think that yes you would lose a bit of oil to the head.. but it being harmfull i cant say
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybridvteceg »</TD></TR><TR><TD CLASS="quote">no not enough pressure. just go from the back with a T.
exactly what i was thinking as well. the dude with the turbo'd LS said that a shop installed it for him. if there isn't enough flow...WTF was the shop thinking? to add to that, the line was pretty small as well.
</TD></TR></TABLE>exactly what i was thinking as well. the dude with the turbo'd LS said that a shop installed it for him. if there isn't enough flow...WTF was the shop thinking? to add to that, the line was pretty small as well.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dunkd »</TD></TR><TR><TD CLASS="quote">no u cant. seals will blow in the turo eventually.</TD></TR></TABLE>
yup, buddy did this on an h22 and his turbo was gone within a month
PyroProblem
Nov 14, 2009 05:16 AM
