oil feed head
Old Feb 18, 2006 | 05:56 PM
640K Crew's Avatar
Default oil feed head
is it ok to use that as the oil source? i searched and old posts have broken pics but i think most people ask if they can tap it from the vetc soleniod.
but the spot in this pic is fine right? cause i need to run water lines to the turbo also and i can run them all together and ziptie them so its not a mess of lines
Old Feb 18, 2006 | 07:28 PM
SOHCD16y8's Avatar
Jut tap off the oil pressure sensor, a lot of times you have problems with Vtec engagement from that point.
Old Feb 18, 2006 | 07:32 PM
640K Crew's Avatar
Default Re: (SOHCD16y8)
well its for a gt30r so i dont think its even pulling very much oil. i dont think its going to pull enough oil to drain the head?
Old Feb 18, 2006 | 08:16 PM
D@nnY's Avatar
Default Re: (Drum and Bass Racing)
you shouldnt take oil away from the head ......run it off the block
Old Feb 18, 2006 | 09:38 PM
SOHCD16y8's Avatar
Why would you risk it anyway, its more work to tap it from there too. Im assuming you will already have the stock sender out to install an OP gauge so you might as well just tap it from there.
Old Feb 19, 2006 | 04:59 AM
BLKEG6T's Avatar
Default Re: oil feed head (Drum and Bass Racing)
just use a oil filter adapter from edelbrock, make things so easy, i have one and so does my buddy.
it's like 70 cdn
http://www.canspeed.com/catalo...Id=23
Old Feb 19, 2006 | 09:52 AM
shortyz21's Avatar
Default Re: oil feed head (BLKEG6T)
sandwich adapters are pointless when u can do the whole setup from the oil pressure sensor for 70$...
just dont mount a tee on the block, it could snap off. put the tees on the firewall.
Old Feb 19, 2006 | 10:22 AM
wantboost's Avatar
Who is Mr Robot?
Default Re: oil feed head (shortyz21)
um no.... a sandwich adapter filters the oil before it goes through the feedline. the oil pressure sensor is dirty unfiltered oil..... think about it
Old Feb 19, 2006 | 12:36 PM
planeman01's Avatar
just get a sandwich adaptor and be done with it...i'm using the golden eagle one and its great...i'm sure the one in the link above will work equaly well....don't mess with pulling oil from the head... just get clean filtered oil from the block
Old Feb 20, 2006 | 05:54 PM
TunerToys's Avatar
Default Regarding oil supply....
We sell the Golden Eagle adapter, and have never had a complaint. We also offer our own fitting for taking oil from the pressure sensor location, no complaint on those either. No brass, and proper threads.
Craig
Dat1BVtecN
Mar 17, 2007 09:17 PM
93h22a1vtec
Dec 19, 2005 04:31 AM
redlineintegra
Jun 10, 2004 03:00 PM
shermanyang
Apr 26, 2004 05:14 PM
krshultz
24
Jul 22, 2002 05:45 AM
