water gauge
Old Apr 26, 2004 | 12:38 PM
93_hatch's Avatar
Default water gauge
hey i just got an autometer water temp gauge was wondering if i install the sender and all can i use the wires autometer gives and trap off one them(which one) to make my stock one still work?
Old Apr 26, 2004 | 12:41 PM
nerdsports's Avatar
Default Re: water gauge (93_hatch)
you have to install the autometer sender somewhere and connect it to the sender position on the gauge. your stock one will still work. just follow the instructions. and you can search the archives on where to mount the sender as well.
good luck.
Old Apr 26, 2004 | 10:38 PM
93_hatch's Avatar
Default Re: water gauge (nerdsports)
yea but can i just swap out the stock sender with the autometer, take the wire for stock the temp and tap in to the autometer wire to have them both working
Old Apr 27, 2004 | 10:39 AM
built562's Avatar
is the guage electrical or mechanical, if its mechanical then it is so much easier, if its electrical its easy also but just remember to ground the sender wherever you install it.
i did mine in a heater hose, i just cut it and went to the hardware store and made an adapter to fit the sensor and put the hose back together
Old May 2, 2004 | 12:49 PM
93_hatch's Avatar
Default Re: water gauge (akumaracer)
how do u install it in the heater hose can u do a write up on it
innes887
Jul 1, 2009 01:30 PM
boostincoupe
Aug 12, 2004 05:36 PM
S@nt0s
Dec 1, 2003 03:23 PM
monicle
May 27, 2003 10:41 AM
speedymon
Apr 30, 2002 11:32 PM
