all noise no go, please help
Old Apr 26, 2004 | 09:59 AM
deljoy's Avatar
Default all noise no go, please help
could any one help with my problem
ive got a civic ivt (sir) its a 1991, with a b16a1 motor, but its lacking performance. the car hits vtec but doesnt go any faster, tried a new distributor, new cams and rockers, new solenoid and lost motion assembly pins, but im stillstruggling to get any performance out the car, the cam timing is spot on, the oil ways in the head are not clogged
i pretty sure the cars hitting vtec cos of the change in engine note, but i cant get much above 85 mph.
could the timing not be advancing, when the vtec opens??
does any one have any suggestions that it could be,
thanks for taking the time to read my post...Deljoy
Old Apr 26, 2004 | 10:07 AM
stockcrix1616's Avatar
Default Re: all noise no go, please help (deljoy)
what kind of exhaust? you still running a cat?
Old Apr 26, 2004 | 10:15 AM
crx_88_si's Avatar
check plugs and wires as well.. fuel filter..and run some injector cleaner through the gas tank
Old Apr 26, 2004 | 10:46 AM
APEX CRX's Avatar
when you replaced the V-tec solenoid did you replace the pressure switch too? Or did you re-use the old one?
Old Apr 27, 2004 | 11:02 AM
deljoy's Avatar
Default Re: all noise no go, please help (APEX CRX)
i replaced the pressure switch at the same time,the car hits vtec but then seems to run out of power, its got me well puzzled
Old Apr 27, 2004 | 11:06 AM
deljoy's Avatar
Default Re: all noise no go, please help (stockcrix1616)
im still running the cat, ive been trying to sort this then planned to stick an exhaust system on
Old Apr 27, 2004 | 11:08 AM
deljoy's Avatar
Default Re: (crx_88_si)
replaced all the fuel lines,ran some injector cleaner through,and fitted new plugs, leads, and cap, but still wont go
Old Apr 27, 2004 | 11:42 AM
riceisnicenv's Avatar
Default Re: (deljoy)
what are you running as far as an ecu... i know some JDM ones have a low speed governer but i wouldn't think itd be that low. someone correct me if i'm wrong on this.
Old Apr 27, 2004 | 11:44 AM
Donkey85's Avatar
do a compression check on him to see if hes healthy. if they are low then you have your answer that hes tired and dosent have much left to give. now if they are all good numbers than i would be looking at timing again, maybe firing order
Old Apr 27, 2004 | 12:49 PM
HF2ZC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by deljoy &raquo;</TD></TR><TR><TD CLASS="quote">im still running the cat, ive been trying to sort this then planned to stick an exhaust system on</TD></TR></TABLE>
Is the cat plugged?
How about the check engine light, is it on?
How old is your air filter? It could be clogged with dirt, hindering performance.
Did you replace the fuel filter when you replaced the lines?
Another idea is that the filter (screen) on the pickup for the fuel pump could be partially blocked by dirt.
the_dxB16
12
Mar 26, 2009 11:55 PM
95civicgsr916
10
Dec 13, 2007 04:00 AM
lshatch1.8
10
Nov 28, 2005 08:51 AM
speedunlimited
Sep 16, 2004 08:08 AM
ls_vtec_crx
Feb 4, 2004 09:43 PM
