who is running low 13's or 12's on a sohc-T with 10-11psi?
Old Apr 26, 2004 | 08:12 AM
yusoslo's Avatar
Default who is running low 13's or 12's on a sohc-T with 10-11psi? what turbo
I think i need a new turbo and want a good available power band and 10-11 psi max.
i was looking at a t3 50trim........42/.63
cause i want quick spooling and atleast 215 to the wheels
so what turbo are you guys using.....13.5's or less is fast enough for me
Old Apr 26, 2004 | 08:15 AM
TravSi's Avatar
Default Re: who is running low 13's or 12's on a sohc-T with 10-11psi? what turbo (yusoslo)
T3 super 60
Old Apr 26, 2004 | 08:32 AM
yusoslo's Avatar
Default Re: who is running low 13's or 12's on a sohc-T with 10-11psi? what turbo (TravSi)
when do you reach full boost....is it streetable?
Old Apr 26, 2004 | 08:43 AM
gitwidit's Avatar
I went 12.8 with a D16 JRSC@10psi and some nitrous
Old Apr 26, 2004 | 10:00 AM
Jockobo's Avatar
Default Re: who is running low 13's or 12's on a sohc-T with 10-11psi? what turbo (GITWIDIT)
i ran a 13.1 on slicks with a t-25 at 12 psi on a d15. the car was 2100 pounds at the time.
Old Apr 26, 2004 | 10:03 AM
yusoslo's Avatar
Default Re: who is running low 13's or 12's on a sohc-T with 10-11psi? what turbo (Jockobo)
thats a nice time, how do you like the t25? does it die uptop?
Old Apr 26, 2004 | 11:35 AM
Jockobo's Avatar
it loses a couple of psi when it approaches 6000 rpms but its nothing too horrible. it's a descent cheap turbo but ill take a t3 over it any day...
Old Apr 26, 2004 | 12:35 PM
D-t's Avatar
D-t
Also the t3 60 trim .60/.48 takes a lil longer to spool, but the power is good, and keeps pulling up top.
Check out Beerbongskickass he's got one on his z6, making good power. This is the turbo im gonna go with as you can see in my sig
Old Apr 26, 2004 | 01:08 PM
yusoslo's Avatar
Default Re: who is running low 13's or 12's on a sohc-T with 10-11psi? what turbo (D-t)
how much do one of the t3 super 60's go for?
Old Apr 26, 2004 | 01:30 PM
Burke's Avatar
Banned
got a built d16z6 pushing 12lbs on a t3/t04e 60 trim .48 ar on hot side. i get 12lbs by like 4k with a manual boost controler. its really pretty freaking sick. not happy with it but i gota12.6 at 110 last week. i'd like lower 12's on 12psi and some 11's on 20 but yea i was missing 2nd gear and still running low 13's
Old Apr 26, 2004 | 03:03 PM
yusoslo's Avatar
Default Re: who is running low 13's or 12's on a sohc-T with 10-11psi? what turbo (Burke)
hey burke that sounds sweet. how much did u pick yours up for?
i dont know if I want a t04e compressor wheel, price and lag are a bit much for me
but 4k isnt laggy at all
Old Apr 26, 2004 | 03:16 PM
onePOINTsix's Avatar
a T3/T4 on a Z6 will be pritty laggy without alot of head work and a hella cam. I'd sugesst a T3 "Super" 60, they are around $400 on ebay, do a search for them on their
Old Apr 26, 2004 | 03:21 PM
Burke's Avatar
Banned
i bought mine off graphiteaccord here on ht. i paid like 375 shipped for it or something. i have a jg head, so that may have something to do with it spooling as fast as it does. i dont know. either way, the thing ******* rocks. it wouldnt spool till almost 6k before i put the mbc on it. now it just flies.
if you go for a to4e comp, make sure you ge a smaller tubine housing for quick spooling
later
burke
Old Apr 26, 2004 | 03:23 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Burke &raquo;</TD></TR><TR><TD CLASS="quote">i bought mine off graphiteaccord here on ht. i paid like 375 shipped for it or something. i have a jg head, so that may have something to do with it spooling as fast as it does. i dont know. either way, the thing ******* rocks. it wouldnt spool till almost 6k before i put the mbc on it. now it just flies.
later
burke</TD></TR></TABLE>to add on to this my firend has a T3/T04e on his SR20DET with a equal length manifold. Even on a 2L it spools at 4000rpm. just some food for thought
Old Apr 26, 2004 | 03:53 PM
turbo_ef9's Avatar
i pulled a 13.3@106 with shitty firestone tires on hx rims.. the setup was a stock z6 with a custom tubular manifold, greddy td05-18g turbo, johnnyracer fmic, 2.25 crush bent dp, stock cat, 2.25 n1 exhaust, xs mbc, and afc hack... this was done at a track that is 2000ft above elevation.. 2.2 60ft times.. it was running 12lbs of boost.. it was an old motor so it blew on the second run.. i ran it hard for about 7 months over 10lbs street driven.. it had blowby, so i figured i would just blow it at the track and see what it would pull.. second run pulled a 13.5@95 after i blew the motor..
Old Apr 26, 2004 | 03:55 PM
turbo_ef9's Avatar
Default Re: who is running low 13's or 12's on a sohc-T with 10-11psi? what turbo (eli_vang)
oh.. and i had about 6lbs of boost at about 4k.. so.. yea..
Old Apr 26, 2004 | 04:10 PM
yusoslo's Avatar
nice times, i dont think the greddy will bolt up to my t3 manifold
why do u think it blew? the hack? or just an old motor
Old Apr 26, 2004 | 04:14 PM
turbo_ef9's Avatar
umm.. well.. when i first installed the mbc, the boost wasn't turning up as i turned it up.. duh.. well anyways.. so i tightened the wg, and left the mbc where it was.. well.. that morning after i did it, i drove it to work and i tested it.. 16-17psi! ahh!! oh ****.. haha.. so after that it had blowby.. it ran strong but i just fucked it up on accident.. it lasted another 2-3 months still after that.. well.. yea.. anyways.. there u go..
Old Apr 26, 2004 | 04:49 PM
fjt's Avatar
fjt
I have a friend that ran 13.8 @10PSI on a Volvo Garret T3 .48. Street tires on a D16y7 Coupe.
12.60sec on same turbo but at 16PSI and Slicks
Old Apr 27, 2004 | 07:01 AM
SOHC_MShue's Avatar
hey bj remember that zex stage 2 cam will help to lower spool up time . You should get one .
Old Apr 27, 2004 | 07:03 AM
yusoslo's Avatar
Default Re: who is running low 13's or 12's on a sohc-T with 10-11psi? what turbo (SOHC_MShue)
yeah i am getting one on my built motor i am doing this summer.......20psi baby
I want a huge area under the dyno curve for usable HP, high flowing head etc etc
vtecspeed1320
Jan 21, 2006 05:28 PM
Terrible One
Jul 12, 2005 09:17 PM
FkingSUV
May 12, 2004 10:23 AM
InTeGrA B18b1
Mar 23, 2003 08:37 PM
RICE POLICE SIP
Dec 17, 2002 03:09 PM
