super 60 t3 turbo
super 60 t3 turbo
has anyone bought a turbo from http://www.cheapturbo.com? Also has anyone heard of the super 60 t3 turbo? I just bought a super 60 turbo from cheap turbo.com and i was wondering if anyone has a super 60 or knows anyone with one and what you or they thought about it.... it's not on my car yet but i'm affraid of what to expect...
Re: super 60 t3 turbo (92boostn'hatch)
i am currently running a t3 super 60... spools super fast!!!... decent power all the way to redline but runs out of breath up top... so it all depends on you application... if you are running a b-series and looking for a really streetable turbo that is great off the line and the low-end... this is a great turbo... but, if you want more top-end power, then i think a t3/t4e would probably suit you better... if you are running a d-series then i think the t3 super 60 is an ideal turbo... so i guess it all depends on what you want to do... good luck and i am sure you will be happy with the turbo... i dont have any personal experience... but cheapturbo.com seems to be a very reputable seller (btw, when i upgrade turbos, i will be buying from him)... do a search... for cheapturbo.com...
Ummm... I dont see a t3 super 60 on http://www.cheapturbos.com
Are you sure you didn't order the t3/60-1?
Re: super 60 t3 turbo (1.8T_EG)
Re: super 60 t3 turbo (Jordo)
http://store.yahoo.com/cheapturbo/gart3sup.html right here buddy
and can you tell us what other parts are you using for your kit...
Re: super 60 t3 turbo (dEF juNKie)
spoolinLs : full boost before i can look at the tach... i would guess 2800... definitely before 3000... but if you are really interested... i can take a look tomorrow (if the roads arent too icy)...
juNKie : see the sig... hehehe... j/j... really basic setup... t3super60, drag log-style manifold, deltagate, spearco intercooler, apexi twin chamber bov, fmu (soon to be custom circuit)... and that is about it... i think...
i didnt look at your sig. and see how much you were boostin
oh yeah...one more question if you dont mind telling me...how much have u spent on your kit and if you could go back...would you have bought a complete kit??
i put my turbo setup together myself and I don't think I would go back and buy a kit.... this way you can get exactly what you want.... You just have to be careful if you buy stuff used.... My car had a turbo in it already but it was used and i leaked oil so it smoked a lot.... so i bought the super 60 turbo BRAND NEW.... but for the most part the other parts in my kit were used.... all together i probably spent (before the super 60) about 1500.... which isn't to bad..... i would have bought the t3/t4 or the t3/60-1 but they didn't have the one i wanted in stock and they were going to get it in, in like a day or two but i needed asap for this friday.....
thanks for answering my questions..
... if i could go back in time though i would still go custom versus a kit, no doubt... but i wish i would have done more research and been more patient... i spent too much money on stuff that i now want replace/upgrade... on me for being to eager to join the darkside... ugh, lessons learned...
Well last night was the night... the last race of the sesson at the las vegas speed way.... at first i couldn't hook up worth $h!T and was running in the low to mid 15's and the very last run i did i ran a 14.47 @96. somthing MPH... that's my best time so far.... even with my big kkk i only ran a 14.5 @ 99.91..... i just had to get used to the low end power..... but i'm very happy with the turbo...
how much psi were you boostin??
and what kinda tires were you on??
quick question if u can answer it...
i currently run a T3 60-trim (.60a/r compressor, .48 turbine, stage 1 wheel) with a tial wastegate. It's diff from the super 60. I get 6psi by like 4k rpm (mainly because no boost controller and i still have the stock cat on 2.5" dp and catback . My turbo is OLD. I'm wondering how a T3 Super 60 would compare to my T3 60-trim in terms of flow and would it be worth changing to a Super 60. And also this is on a stock block D16Y8... the most i will be running on the stock block is say 10psi until i decide to swap or build this motor.
EDIT:
Just saw the specs of the Super 60 on the site... how would this...
Compressor:
Super 60 wheel, .42 A/R housing
FLOW: 35LBS/MIN
Turbine:
68 TRIM WHEEL
.48 A/R housing
compare to mine:
T3 60-trim, .60 a/r compressor side
.48 turbine side w/ stage 1 wheel
saw a CFM flow chart said it flowed 490CFM
[Modified by CivicRyda2k, 5:52 PM 12/7/2002]
[Modified by CivicRyda2k, 5:55 PM 12/7/2002]
EDIT:
Compressor:
FLOW: 35LBS/MIN
Turbine:
68 TRIM WHEEL
.48 A/R housing
compare to mine:
14.5@99.91...thats pretty good..
I don’t know how to do the whole quote thing so I just cut and paste when I had my kkk turbo on I was running 5lbs of boost with bald falken street tires. This time I’m running 8lbs of boost with the same tires and it’s way colder outside…. And for some reason I’m boosting 8lbs but before I changed the turbo I was only boosting 5lbs…. all I did was change the turbo ….. does anyone know why I’m boosting more now… I’m using the deltagate wastegate…. And I didn’t adjust anything, just changed turbos…
Re: super 60 t3 turbo (CivicRyda2k)
I'm not sure exacty whats different.... all i know is the turbo that i bought has a .48 a/r turbine housing and a .42 a/r compressor housing with a 60 or 68 trim wheel which has been "clipped".... that's what it's called i guess... But i like mine a lot.... it's almost at 5-6 lbs of boost by 2-3 grand.... it has a lot of low end... i love it.... If you give the guys at http://www.cheapturbo.com ask for ken and he'll tell you all that you need to know....
hey how do you do the whole quote thing? also i'm using an external wastegate and no boost controller.... i didn't change anthing at all... all i did was change the turbo....
[quote] lalalalalal [quote]
but put a / before the 2nd word quote
Or click "reply" on the person's post, then hit quote orignial post on the bottom
Re: super 60 t3 turbo (GOLDBERG)
can someone tell me the difference between the super 60 T3 and the t3/60-1??? thnx
a T3/60-1 is a T3 with a T04S compressor with a 60 trim wheel... not sure if it's a special "60-1" wheel or it's just denoted by 60 trim
has anyone used a t3 on a SOHC motor? If so how much could you boost safely and what motor was it?
The super 60 compressor can flow enough to make 275-300 whp.
the 60 trim slightly less.
You guys that are having 'top end' flow issues, otta try a .63 A/R turbine
housing. Yeah you have a little slower respone, but you'll flow
better on the top end. (you're resrticting the exhaust too much with
your current .48 housing)
Basically all the 1.8 and 2.0L VW guys stay away from the .48 turbine housing unless they intend to keep power below 200hp, want 'instant' response, or
bought a 'junkyard' turbo that already has it.
One or two of them has the .82 A/R housing, it spools late, but peak power is
made after 7000 rpm...(for drag racing apps)
Just my opinion
Jeffrey Atwood
Just my opinion
Jeffrey Atwood
hondahatch741
05-30-2005 12:36 PM
