Will a 99 D series prim O2 fit my 99 SI????
Old Apr 25, 2004 | 09:14 AM
TwistedSI's Avatar
Default Will a 99 D series prim O2 fit my 99 SI????
Are they the same? I know the d-series is a 4 wire.
Old Apr 25, 2004 | 09:42 AM
TwistedSI's Avatar
Anyone?
Old Apr 25, 2004 | 09:46 AM
freakin_eLRoD's Avatar
Default Re: Will a 99 D series prim O2 fit my 99 SI???? (TwistedSI)
It should work. I ran 98 GSR primary and secondary o2 sensors on my 96 ex for smog and I passed emissions fine (keep in mind I live in the state of smog ****'s).
Old Apr 25, 2004 | 04:08 PM
vtecpower1062's Avatar
Default Re: Will a 99 D series prim O2 fit my 99 SI???? (powerBan.est1990)
Looking up the 99 EX primary O2 sensor the part number is 36531-P2P-A01 (Honda Code 600020). That O2 sensor only cross refrences to 99 and 00 Civic EX 2 and 4dr models only. The Civic Si primary O2 sensor part number is 36531-P2T-003 (Honda code 601826) and that fits the 99-00 Civic Si. I wouldn't recommend using the D-series O2 sensor because im pretty sure there is a big enough difference between the D-series O2 sensor and the Si O2 sensor that you may have a problem if you try to use a D-series O2 sensor. Hope this helps.
Old Apr 26, 2004 | 08:56 AM
civic-4-ges's Avatar
Default Re: Will a 99 D series prim O2 fit my 99 SI???? (vtecpower1062)
Only real difference between the two part numbers are the wires on the two o2 sensors. Otherwise they are interchangable
N1YDP
15
Feb 22, 2015 12:12 PM
mikeski
Dec 22, 2011 01:23 AM
cwf1988
May 26, 2008 12:58 PM
JohnnieChimpo
May 25, 2004 05:11 AM
99CivicSi
Apr 22, 2002 04:27 PM
