Help I cant shift !
Old Apr 23, 2004 | 04:15 PM
DC2-JRSC'd's Avatar
Default Help I cant shift !
I am so pissed right now. Here's my problem:
I bought an 89 Civic Si and i plan on turbocharging it so this weekend i said let me upgrade the clutch. So I bought an 1991 ACT pressure plate with a 6-puck disk. Of course that means i needed to also get the bigger flywheel. No big deal a friend gave me his flywheel from a 93 hatch, i think. I also replaced the throw out bearing and the transmission fluid.
Anyways to make a long story short i just got done a couple hours ago but the damn thing doesn't want to shift into any gears. I have to start it in neutral and when i try to change gears it acts as if im trying to change them without pressing in the clutch and the engine wants to stall. I tried adjusting the clutch cable with no luck. If the car is off i can go through all the gears with no problem so i don't think the transmission took a poop. Also the clutch is hard just like an act should be so that makes me think the throw out bearing is installed right.
What else could it be? Im going nuts here, i really wanted to drive it test the new clutch.
Old Apr 23, 2004 | 04:16 PM
B2FiNiTY's Avatar
Default Re: Help I cant shift ! (dan4g63)
Did you use a clutch alignment tool?
Old Apr 23, 2004 | 04:18 PM
DC2-JRSC'd's Avatar
Default Re: Help I cant shift ! (B2FiNiTY)
Yes!
Old Apr 23, 2004 | 04:35 PM
96-EJ6 B18C's Avatar
Will it shift of the car is not on? What does the shifter feel like? (ie. loose, sloppy, very stiff) Is the clutch cable properly adjusted?
Old Apr 23, 2004 | 04:41 PM
track_onslaught's Avatar
do you have a cable or hydro clutch ??
if you have hydro clutch do you have pressure?? make sure there is no air in your system. that killed me for a while when i swapped my engine in my 240.
Old Apr 23, 2004 | 04:58 PM
DC2-JRSC'd's Avatar
Default Re: Help I cant shift ! (track_onslaught)
I have cable.
Yes i can shift when the car is off.
The shifter feels good. Its not sloppy or loose.
I think i adjusted the cluch cable at least 50 times. I went from one end to the other so i have no idea what properlly adjusted means anymore.
Old Apr 23, 2004 | 05:07 PM
Kasper.'s Avatar
what happens if you start the car in gear?
Old Apr 23, 2004 | 05:22 PM
DC2-JRSC'd's Avatar
Default Re: Help I cant shift ! (Kasper-EF8)
It will not start and it jerks forward.
Old Apr 23, 2004 | 05:28 PM
Kasper.'s Avatar
well then it sounds like your clutch is simply not engaging onto the flywheel-actually sounds like its already engaged and not disengaging.....somthings wrong with your clutch cable or your clutch fork/t/obearing.
Your going to have to either replace the clutch cable or take it all apart and see what you messed up.
Modified by Kasper-EF8 at 6:49 PM 4/23/2004
Old Apr 23, 2004 | 05:36 PM
Proper adjustment would be having the cable snug enough so there is minimal play when you pull up on the arm that actuates the release bearing.
Are there anymore details that you can think of that may be helpful?
Old Apr 23, 2004 | 05:37 PM
HamiltonRex's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dan4g63 &raquo;</TD></TR><TR><TD CLASS="quote">It will not start and it jerks forward.</TD></TR></TABLE>
Mine did that, was working fine then all of a sudden started that ****.
My dad hops in, i hear a nasty *** grind for like a second maybe, he drives it around the block and it was all good. He did something i dont know what. It was almost like the clutch was not disengaging or something.. I dont know.
When adjusting clutch cable, tighten the cable JUST like a thread before tension starts. Well thats how mine is, dont know if its right or not.
-Eric
Old Apr 23, 2004 | 06:38 PM
DC2-JRSC'd's Avatar
Well the throw-out bearing i bought was for a 89 but all 89-91 use the same throw out bearing correct?
Another thing when i adjust the cable and just when the tension starts theres a noise coming out of the tranny. Its not loud but its there and it sounds like grinding.
I dont know what to do i guess ill have to take it all apart but thats not going to be for a month or two because of my schedule.
Old Apr 23, 2004 | 08:12 PM
payneth's Avatar
Default Re: (dan4g63)
i had the same problem, and a new clutch cable fixed it for me.
Old Apr 23, 2004 | 08:21 PM
DC2-JRSC'd's Avatar
Default Re: (Payneth)
Is there a way I can check see if my cable's bad?
If i have a friend pull up the arm that actuates the release bearing should i be able to change gears then?
Old Apr 23, 2004 | 08:27 PM
lightcrx's Avatar
i think you have to reset the clutch, this happens on new pp's just push it in and out a bounch of times with the car off, and see if it helps
Old Apr 23, 2004 | 08:41 PM
HatchBox's Avatar
Skoobie no more...
Default Re: (lightcrx)
can you pull up on the arm when the cable isnt attached to it?
Old Apr 23, 2004 | 09:01 PM
DC2-JRSC'd's Avatar
Default Re: (Hybrid Hatchback)
yes i can. If i pull on the arm i should be able to shift right? (if were assuming the clutch cable is the problem here)
Old Apr 24, 2004 | 06:18 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hybrid Hatchback &raquo;</TD></TR><TR><TD CLASS="quote">can you pull up on the arm when the cable isnt attached to it?</TD></TR></TABLE>
Maybe if your Hercules,
I sure know theres way to much tension on that arm for me to pull the damn thing up.
-Eric
Old Apr 24, 2004 | 07:06 AM
spaceman's Avatar
Default Re: (HamiltonRex)
lol...dood either your cable isnt adjusted properly,you didnt get the correct parts or they were not installed correctly...i would try adjusting the cable first...good luck
hojoR
Aug 17, 2009 01:01 PM
JDMCivicEF9
Jul 4, 2006 03:51 AM
99simoder
Nov 20, 2005 08:18 PM
LowAcura
Apr 20, 2003 04:30 PM
WhiteDA9
Oct 22, 2002 08:12 PM
