poor mans type R
Old Apr 23, 2004 | 02:47 PM
DOHC VTEC EG's Avatar
Default poor mans type R
what is the point of putting a b16 head on a gsr block if it lowers the compression..
are you supposed to build the block first??
Old Apr 23, 2004 | 06:17 PM
b20dc2's Avatar
Default Re: poor mans type R (DOHC VTEC EG)
breaths a little better
Old Apr 23, 2004 | 06:38 PM
usdm420's Avatar
816d16 owes me money!
Community Builder
Community Influencer
Active Streak: 30 Days
Default Re: poor mans type R (b20dc2)
you can basically form a "budget" version of a c5 with a p72 block and a pr3 head. with some internal upgrades you have a nice high-revving frankenstein motor of a different sort. a little more displacement helps out a little with the torque problems usually associated with a b16, and keeps the top-end power with a head that can be built identical to a c5. upgrade your pistons and your low compression problems will be history
Old Apr 23, 2004 | 09:08 PM
sweet thanks
Old Apr 28, 2004 | 06:23 PM
FATBOYeg6's Avatar
Default Re: (DOHC VTEC EG)
usually when you do a poor mans type r, you switch the pistons also. im debating between the "poor mans R" and a b16 stroked with ls crank and rods. still got some research to do, but i think i know what i am going to do.
itz_nij
Aug 28, 2006 10:12 AM
jmpgraphy
Aug 15, 2006 10:37 AM
Cheez-It
Jul 19, 2006 04:32 PM
7rrivera7
Sep 17, 2003 09:58 AM
Nextelbuddy
15
Jun 2, 2003 10:58 AM
