Best D-series (stock) for turbo 8psi???
Old Apr 23, 2004 | 03:58 AM
likaciv's Avatar
Default Best D-series (stock) for turbo 8psi???
Like the headding says, im looking for peoples opinions/expiriences with turboing a d-series in an Ef civic. Any opinions would be great
Old Apr 23, 2004 | 06:35 AM
MooreBoost's Avatar
Default Re: Best D-series (stock) for turbo 8psi??? (likaciv)
I will be running this setup-
14b turbo
HF Manifold
BMC Racing adapter plate
SAFC
DSM 450's
DSM 1g Sidemount
DSM 1g BOV
TurboXS MBC
Old Apr 23, 2004 | 06:58 AM
90SICRX's Avatar
In my opinion the ZC DOHC really takes a turbo nice. I have a friend with a DOHC ZC T3/T4 turbo with nothing done to the internals and it runs great. But thats just my opinion.
Old Apr 23, 2004 | 07:04 AM
therealciviczc's Avatar
I did my ZC. With very moderate boost levels I was running around a 14.0-14.2 in a Civic Si hatch on just average every day tires. I was getting 2.2 - 2.4 60fts.
I don't know how that compares to others with similar cars, but the ZC seemed to like the boost. If it got even a shred of traction it would probably be in the 13s easily. Its really fun on the highway once you're already moving.
I have a Greddy SOHC kit with around 7psi using a crappy FMU setup and an Si trans.
Even though there is nothing technical about which motor is good, hopefully my experience will help a little. Also, I didn't put this out there so that someone can tell me that their uncles, neighbor's, friend's, highschool teacher's, boy'z HF with a destroked and detuned 1.5 liter runs 9s with no tires and a 300lb fat girl in the hatch.
Old Apr 23, 2004 | 07:14 AM
90SICRX's Avatar
hahahaha very well put
Old Apr 23, 2004 | 08:03 AM
likaciv's Avatar
Default Re: (90SICRX)
thanks for the replys,
The zc seems to be the choice (cheap) turbo solution, but I may go with a z6 or a6 and boost that.
Any thoughts on installing a 93 z6 in a 91 lx?? Direct bolt on with Mpfi converison on car, or is specific mounts needed, and what about axles?
Old Apr 23, 2004 | 08:12 AM
FlexW99's Avatar
Default Re: (likaciv)
well...no difference really....a zc and d16 are limited to the same weak weak rods and pistons...
Old Apr 23, 2004 | 08:14 AM
Machine1's Avatar
We had a D15B7(92 DX) with a T25(Eclipse) turbo in an 89 Hatch
ARP studs
Cometic headgasket
Apexi super AFC
DSM 450cc injectors
Saab intercooler
Crane stage 3 turbo cam
stock internals
It ran a 13.1@103 at 12psi boost with 22x8x15 M/T slicks
Unfortunately a leaky heater hose decided to fill the speedometer cable hole on the transmission with some of that green stuff.
Old Apr 23, 2004 | 08:52 AM
TAG's Avatar
TAG
Default Re: Best D-series (Machine1)
Another recommendation for the ZC here.
I have a stock ZC in my 90 CRX Si.
With the Greddy kit I'm making around 240hp and 200+ tq.
It's very fast, and I've had no problems whatsoever.
Setup is: 10psi, Spearco FMIC, 450ccs, ZDyne and some good tuning.
The ZC just seem to like boost. -Enjoy
Old Apr 23, 2004 | 11:46 AM
96-EJ6 B18C's Avatar
Default Re: Best D-series (TAG)
I'll be boosting my A6 here in a few weeks (hopefully) I will keep everyone posted and to how that goes. Here is my setup:
SS Autochrome manifold
Air Research T3 .42 A/R at about 7psi to start
Custom 20x8 cooler
Custom Piping
Custom Down pipe
GReddy Type S BOV
DSM 450's running on Uberdata
AEM UEGO Wide Band O2
I guess we'll see how it does here very soon
Old Apr 23, 2004 | 12:45 PM
HumanResource's Avatar
use what ever is in better shape
8psi ain't gun hurt nobody, but it would hurt an already beat engine
Old Apr 23, 2004 | 01:22 PM
Mr Hammond's Avatar
a/k/a Jomo
Well open deck, weak rods and weaker ring lands. Take your pick. None of them are exactly "well suited" for boost.
Old Apr 25, 2004 | 02:33 PM
likaciv's Avatar
Default Re: Best D-series (Mr Milano)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr Milano &raquo;</TD></TR><TR><TD CLASS="quote">Well open deck, weak rods and weaker ring lands. Take your pick. None of them are exactly "well suited" for boost.</TD></TR></TABLE>
True, but as HumanResource said as long as its just at 8psi, I should be ok, It is of course a d series, disposable as hell!
lunaticracer21
May 7, 2007 10:17 PM
sleepin91teg
Feb 11, 2005 02:16 PM
RustyRex
May 20, 2003 04:08 AM
RustyRex
12
May 11, 2003 10:32 PM
