how much HP can I get out of a stock dohc zc with out blowing it???help
I have a t25 turbo, f22 injecters, nice lil frontmount, fmu, greddy bov s1, 2,25 pipeing,hks turbo timer,also just thinking if I should keep the boost at like 8psi. I don't wonna blow my motor what psi do you guys think is safe 4 a dohc zc
Re: how much HP can I get out of a stock dohc zc with out blowing it???help (lunaticracer21)
my buddy has a dohc zc, he has had it turboed for about 2 years w/ a t25 and dsm injectors @ 10psi he was making " i think" 200-220 whp. and just recently he is noticing alot of blowby
N/e one eles I'm trying 2 get as much info that I can plz help ppl....
Re: (lunaticracer21)
Well the ACCEL fuel injector chart I have lists 235cc injectors for every F22, so I would suspect that with the FMU you'll run lean before you max that motor out.
Also since its going to be 'tuned' with an FMU, you'll have a hard time coming close to 200whp with 8psi on anything but a big turbo for a zc, like a 57trim t3/t04e. I'll bet that if it blows, it won't be from too much power - it will be due to an odd lean condition that comes out of nowhere, or a boost spike that the maxed out fuel system can't handle.
you can use eclipse turbo inejctors yes.... but you have to reprogram your ecu. otherwise at idle it dumps 2x factory fuel(450cc injectors are justa out twice as big as your factroy 240cc) your F22 are useless... i think they are the exact same as your ZC injectors. if you just throw in dsm 450's your car will barly even start. you have to calibrate the ecu so it knows that there are bigger injectors. and then you need to tune it to proper AFR's(or dyno for power)
edit: FMU + DSM450(eclipse turbo) wont work figured ide just say that straight out. you need to modify your ecu.
I need all the help I can get so if n/e 1 eles can help then kool thanks guys
OutLuDeD
04-17-2003 10:31 AM
