z6 and y8....all parts interchangeable???
Old Apr 21, 2004 | 09:16 PM
z6's Avatar
z6
Default z6 and y8....all parts interchangeable???
i just bought 9:1 c.r. pistons, forged rods, and a zex 59300cam for my z6....then i got an offer i couldnt refuse for my 94 ex-coupe...so is it ok to use these in a y8? cuz im buyin a 98 ex-coupe now. will the c.r. be the same? rods work? cam fit?
i've also noticed there is a larger aftermarket for the z6 motors...will i be able to use all of those parts for my new y8?
Old Apr 21, 2004 | 09:18 PM
skip.two's Avatar
Default Re: z6 and y8....all parts interchangeable??? (z6)
yes the parts are interchangeable. your cr will be different. i'm thinking it will be a little higher.
Old Apr 21, 2004 | 09:28 PM
illicon2003
Guest
Posts: n/a
the oil pans won't swap just to let you know
Old Apr 21, 2004 | 09:30 PM
NonovUrbizniz's Avatar
Loved
Default Re: (illicon2003)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by illicon2003 &raquo;</TD></TR><TR><TD CLASS="quote">the oil pans won't swap just to let you know</TD></TR></TABLE>
Really??
I thought that was a common thing for people to use the Y8 oil pan on a z6 because it's aluminum...
Old Apr 21, 2004 | 09:36 PM
z6's Avatar
z6
see....little things like these get me nervous
Old Apr 21, 2004 | 10:34 PM
Br1anPham's Avatar
Default Re: (z6)
can anyone confirm that oilpans arent interchangeable??
Old Apr 21, 2004 | 10:47 PM
robtec's Avatar
Default Re: (Br1anPham)
i don't know about the olipans,but the oil pump is not interchangeable,i once ordered a y8 oil pump for my y8 block,and they send me a z6 pump,after i installe it,i realize that it doesn't have the openning for the oil dip stick
the trannys are interchangeable,i was using a z6 and now i am using a y8 one.
the cams are interchangeable,but a z6 cam installed on a y8 is off 5 degrees and viceversa.
Old Apr 23, 2004 | 01:10 PM
Loved
Default Re: (robtec)
Bump because I'm sure someone here has tried to fit a y8 oilpan to a z6...
sirsol66
15
Sep 11, 2006 09:59 AM
SRd240sx
Aug 7, 2006 05:19 AM
97_boostedcivic
Nov 5, 2005 08:20 PM
SiR HatchAlot
Mar 19, 2005 10:28 PM
phatrick2332
Dec 7, 2003 07:39 AM
