jdm d15b ecu
Read the rules and regs. of the forum and try reposting with a more detailed title. You probaly will get more repsonses.
This is'nt a flame just a helpful tip to get the info you need from someone who knows it.
A P28 will work, but it will run a little rich. The P08 is the right ECU for the D15B, but it is made for a one wire o2 sensor. Let me know the specifics of your setup and I might be able to set you up with a P28 programmed to run your motor, or a P08 ECU with the o2 heater enabled (for 4 wire o2 sensor).
laoboisosilly
Mar 10, 2007 07:59 AM
