is my block aluminum?
Old Apr 19, 2004 | 09:48 AM
_HANS's Avatar
From: new jersey home of wanna be's posers claimers ricers biters and where everyone fakes the funk
Default is my block aluminum?
i have a 1994 vx hatch 1.5 vtec-e motor. ive been told its an alum. block i plan on putting a turbo kit with low low boost on this motor within a week. let me know
Old Apr 19, 2004 | 09:55 AM
EKhatch's Avatar
Default Re: is my block aluminum? (NJHatch)
Yes
Old Apr 19, 2004 | 09:59 AM
_HANS's Avatar
Default Re: is my block aluminum? (EKhatch)
so dont go turbo? with a good setup with low boost?
Old Apr 19, 2004 | 10:00 AM
skip.two's Avatar
dont be afraid to boost. your block will be fine.
Old Apr 19, 2004 | 10:03 AM
_HANS's Avatar
Default Re: is my block aluminum? (jL iLLuZiOnz 9)
ya think? im running a t3 .48 .60 trim with a fmic, intercooler piping, vafc, resistors,my car has about 134k on it,450's and i wanna run about 3 lbs daily(i use my car alot) im debating what to do now.
Old Apr 19, 2004 | 10:18 AM
pwrofdrm's Avatar
you can safely run more than 3lbs....if you're only going to run 3 lbs of boost, why waste the money? Your gains will not be substantial. In that case you'd be better off with a couple of all-motor bolt-ons
Old Apr 19, 2004 | 10:22 AM
dunkd's Avatar
all honda blocks are aluminum...
Old Apr 19, 2004 | 10:24 AM
BauleyCivic's Avatar
Risky Business
Default Re: (dunkd)
The VX head, block, and transmission are all ****. I would suggest upgrading to a Civic DX (D15B7) or Civic EX (D16Z6) motor and then boosting.
Old Apr 19, 2004 | 10:28 AM
Kamin's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NJHatch &raquo;</TD></TR><TR><TD CLASS="quote">ya think? im running a t3 .48 .60 trim with a fmic, intercooler piping, vafc, resistors,my car has about 134k on it,450's and i wanna run about 3 lbs daily(i use my car alot) im debating what to do now.</TD></TR></TABLE>
3 psi? dude i make 3 psi when i sneeze. you wont even feel it.
you will be more than safe to run 5 lbs daily.
Old Apr 19, 2004 | 10:30 AM
skip.two's Avatar
Default Re: is my block aluminum? (Kamin)
yea, at least 5-7psi daily
Old Apr 19, 2004 | 10:34 AM
_HANS's Avatar
yea 5-7 sounds good
Old Apr 19, 2004 | 10:41 AM
B18C5-EH2's Avatar
Former Moderator
Loved
Default Re: (dunkd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dunkd &raquo;</TD></TR><TR><TD CLASS="quote">all honda blocks are aluminum...</TD></TR></TABLE>
No they are not.
1989-below Accord blocks and a lot of older Civics, etc. had iron blocks.
Anyways yes your block is aluminum (all 1988-up Civics are), but that is not your main problem when trying to boost a stock VX engine.
The shitty pencil-thin rods and weak cast pistons will be your biggest problem with boosting that engine.
I say don't waste your time. The VX makes 92hp stock and even on 5psi or so it will still not be worth the trouble.
I'd start with nothing less than a 1.6L SOHC and maybe even throw in some stronger 1986-1987 Integra rods and then I'd probably feel okay about 10psi or so AFTER tuning.
I guarantee you will blow that 1.5L bottom end up on even 5psi - I'd bet money on it.
Old Apr 19, 2004 | 04:48 PM
_HANS's Avatar
Default Re: (B18C5-EH2)
i dont know what to do now? boost or no boost?
Old Apr 19, 2004 | 04:50 PM
_HANS's Avatar
Default Re: (NJHatch)
who has boosted 1.5 motors? d15z1?
Old Apr 19, 2004 | 04:53 PM
Ricey McRicerton's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NJHatch &raquo;</TD></TR><TR><TD CLASS="quote">who has boosted 1.5 motors? d15z1?</TD></TR></TABLE>
Apparently you aernt listening. For the cost/dollar ratio swapping in a D16z6 engine is your best bet and then turbo that. The VX is a crappy engine with an even crappier transmission bolted to it.
Old Apr 19, 2004 | 05:00 PM
Archidictus's Avatar
Unceasing Measure
No one, because they either:
A.) realized that it was a mistake and didn't do it or
B.) failed to listen to sage advice and blew apart the paper-mache' motor that comprises the VX's go-parts.
Don't boost it when you can buy a D15B or D16Z6 for under $600.
EDIT: my roommate runs 15.7 daily, peaking at 22 when we get "randy". His block ain't aluminum, though .
lunch_box_4_life
Nov 10, 2008 09:51 AM
primerEG
Apr 25, 2008 09:51 AM
CivicGSR225
Oct 15, 2004 03:17 AM
wm5holla
May 1, 2003 07:48 AM
94TealGSR
Feb 8, 2003 08:39 AM
