another IACV just a quick question
Old Apr 14, 2004 | 01:35 PM
JDMlyfestyle's Avatar
Default another IACV just a quick question
Ok my idle is ******* annoying big time. i cant stand it. and i unplugged the IACV and the idle went back to normal. so do i need a new IACV? is it safe to drive without the IACV hooked up. comeon guys help out
right click and save as. We-todd might be down
Video http://www.we-todd-did-racing....DE%3D
thanks
jason
Modified by JDMlifestyle at 5:53 PM 4/15/2004
Old Apr 14, 2004 | 02:12 PM
I need a answer
Old Apr 14, 2004 | 03:12 PM
pacifico's Avatar
Default Re: (JDMlifestyle)
i have one for sale on ebay! Check it out
http://cgi.ebay.com/ebaymotors...%3AIT
Old Apr 14, 2004 | 06:38 PM
lalalalalala ne one here?
Old Apr 14, 2004 | 07:21 PM
hatchi's Avatar
Default Re: another IACV just a quick question (JDMlifestyle)
is your idle fluctuating?? you either have to clean it out or replace it. are you throwing any ecu codes??
Old Apr 14, 2004 | 07:41 PM
nope no codes. but when i cover the hole inside the TB or if i unplug the IAC the idle goes back to normal
Old Apr 14, 2004 | 09:24 PM
hatchi's Avatar
Default Re: another IACV just a quick question (hatchi)
take it out and clean the screen on it as it may be clogged with dirt
Old Apr 14, 2004 | 10:53 PM
i have already taken it apart and cleaned it. use some break cleaner let it dry for 2 hours and hit it with a lil of compressed air. i installed it and the idle just sits at 2 k now
Old Apr 15, 2004 | 04:59 AM
EE_Chris's Avatar
When you cover up the throttle body holes, what does the idle come down to? If it comes to down to a 'normal' operating range, like 750rpm, you have a vacuum leak. When you disable the idling subsystems, like the IACV and FITV (if you have it), the only air that should bypass the throttle plate is by way of the idle air bypass screw. This screw should only let enough air into the manifold to sustain about a 500rpm idle, termed the base idle speed. By plugging in the IACV, the idle should increase to about 750rpm, termed the curb idle speed. This is for 2-wire IACV's however as the 3-wire version operates totally different.
Old Apr 15, 2004 | 10:30 AM
i have no clue where the leak is i checked all the vaccum hoses. and everything is connected and its still got me stumped. When i took off the Intake manifole the gasket seemed to be pretty damn new. everything is tighened down. so i have no clue what to think
Old Apr 15, 2004 | 11:42 AM
oldbeefcake's Avatar
vacuum leak will make the idle surge (goes up and down). I think you need to replace that unit. But it should be fine to run it unplugged, since it is warm outside. Try to reset the ecu after you unplug it, because the HELM says to troublshoot it this way.
Old Apr 15, 2004 | 11:47 AM
The idle isnt really surging at all. it just pops up and sits at 2 grand and very slowly works its way down to 1500 and it stays there til i stop again or push in the clutch
Old Apr 15, 2004 | 12:58 PM
i reset the ECU and i started the car and it just died. it wont run without it after i reset the ecu. Can someone local donate me a IACV?
Old Apr 15, 2004 | 01:53 PM
Added a older video so u guys know what i mean
Old Apr 15, 2004 | 06:58 PM
McNizzle's Avatar
hm i had the same exact problem and i just took off the throttle body and plugged one of the holes and everything is fine now...should i still get it replaced though?
Old Apr 15, 2004 | 08:58 PM
can you just plug the hole that controls the IACV?
JDMPanda503
May 9, 2010 01:21 PM
L_K
Jun 30, 2007 09:48 AM
DelSolSi93
Sep 5, 2004 08:27 PM
whoobeedoobee
Jun 25, 2004 06:39 AM
otakueric
Apr 29, 2004 09:00 PM
