Spring Help PLEASE>>
Old Apr 14, 2004 | 12:48 PM
clutch33's Avatar
Default Spring Help PLEASE>>
I am in the middle of installing spring on my civic and I need help. I am trying to remove the center bolt on top of the shock assembly. It said to use a 5mm allen wrench to hold and a 14 mm wrench to turn it. Well all I had was a 3/16. All it's to small and a 7/32 is to big. Now I think the allen key bolt is stripped. How do I get it out??????
Old Apr 14, 2004 | 12:59 PM
clutch33's Avatar
Default Re: Spring Help PLEASE>> (clutch33)
Bump...Please.
Old Apr 14, 2004 | 01:03 PM
BeerMan's Avatar
I've done this before, more than once. I hate those nuts.
I got lucky and powered it off with an impact wrench. The other time I just sawed it off. But, I only need the top hats in that instance.
And once again, this happened to a friend. We sawed it off and bought a new strut. Gabriel brand at Autozone, $70 or something, it performs well enough. You are right down the street from one right? off of rt 40?
Old Apr 14, 2004 | 01:05 PM
clutch33's Avatar
anyone else...
Old Apr 14, 2004 | 02:25 PM
North_Texas's Avatar
If you stripped it, saw it off. Other than that, I can't tell you. Cause you don't have any wrench's that fit. Unless you can get a hand on an impact gun.
Old Apr 14, 2004 | 02:35 PM
nonsense's Avatar
get some more alan wrenches and see if one fits better. You mey have to hammer it in to get it to fit. Otherwise, cut the nut off.
Old Apr 14, 2004 | 08:35 PM
Default Re: Spring Help PLEASE>> (nonsense)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nonsense &raquo;</TD></TR><TR><TD CLASS="quote">get some more alan wrenches and see if one fits better. You mey have to hammer it in to get it to fit. Otherwise, cut the nut off.
I hammered mine in there. Friend sawed his off. Either way should help. Ghetto but w.e.
Old Apr 14, 2004 | 08:50 PM
Superdragr45's Avatar
Default Re: Spring Help PLEASE>> (Blk_Guy_N_S3DAN)
ran into this problem a week ago swapping springs out........im just gonna buy new struts and springs now......
if i were u, i would saw that shiet off.......i tried two allen wrenches and it stripped the inside of the strut each time.
Old Apr 15, 2004 | 11:34 AM
atermizi's Avatar
Default Re: Spring Help PLEASE>> (Superdragr45)
go to any workshop..they have an impact wrench and it only take them 5 seconds to take the top off. that's waht i did.
luder23
Apr 5, 2013 06:28 PM
seeeya04
Suspension & Brakes
10
Jan 16, 2005 06:24 PM
clutch33
Apr 14, 2004 07:49 PM
MachAF
Mar 23, 2003 08:20 AM
MachAF
Mar 23, 2003 03:42 AM
