D16 Turbo problems... [long?]
Old Apr 12, 2004 | 02:28 PM
90civichb's Avatar
Default D16 Turbo problems... [long?]
The previous owner of the 1995 del sol turbo in my signature installed the kit.
It is non intercooled and is set at 5 psi...
I was unaware that the oil seals were bad on the turbo prior to purchasing it, and since I don't drive it hard all the time, no signs could be seen.
I had a friend take it to the track and run it, and it did a best of a 15.4 1/4 mile.
After two runs we noticed some oil on the front bumper and opened the hood to find out that oil was soaking one of the silicone couplers.. This is how we realized that the oil seal had blown..
Now.. with oil getting in to the engine through the intake, would this be the reason for the lower 1/4 mile time, or would that not significantly effect it?
He said he saw the boost gauge creep to between 8 and 8.5 psi while running it on the 15.4 run...
Someone help me out here..
also, anyone know a place in the ky/tn area that would replace the oil seals on this t25 for a good price?
Old Apr 12, 2004 | 02:32 PM
90civichb's Avatar
Default Re: D16 Turbo problems... [long?] (90civichb)
The shop that installed the kit said that they installed the same kit on another del sol si, and it ran a 14.4 1/4 mile without the 255lph fuel pump........
Old Apr 12, 2004 | 02:34 PM
markpa2's Avatar
Runnning turbo and no intercooler on a d series motor is the stupidest thing one person can do.Do yourself a favour and pick up atleast a sidemount of a dsm, and youll save yourelf headaces later on.
Old Apr 12, 2004 | 02:51 PM
Marauder's Avatar
Default Re: D16 Turbo problems... [long?] (markpa2)
5 psi and non-intercooled, I wouldn't expect too much better than that.
From Car & Driver, a Del Sol with stock engine does the following for 1/8 and 1/4 times
1993 Honda Civic del Sol Si 8.8 16.8
Old Apr 12, 2004 | 03:06 PM
90civichb's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by markpa2 &raquo;</TD></TR><TR><TD CLASS="quote">Runnning turbo and no intercooler on a d series motor is the stupidest thing one person can do.Do yourself a favour and pick up atleast a sidemount of a dsm, and youll save yourelf headaces later on.
Do me a favor and spare me the pointless posts.. Lots of people run non-intercooled with no problems, and the fact that it is a d series DOESN'T MATTER..
Anyways.. I just bought this:
Old Apr 12, 2004 | 03:15 PM
Shaun's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90civichb &raquo;</TD></TR><TR><TD CLASS="quote">
Do me a favor and spare me the pointless posts.. Lots of people run non-intercooled with no problems, and the fact that it is a d series DOESN'T MATTER..</TD></TR></TABLE>
haha thank you
Old Apr 26, 2004 | 06:57 PM
B18Tahtaras's Avatar
I think it was a bad day, Do you know how many miles were on the turbo when you bought the car?
Also, some turbos hold up to non intercooled setups better then others. were the charge pipes wrapped with a an insulant, as well as the headers? Alot of things come into play when trying to pinpoint the cause of a problem like that. The turbo could've been old, with mild shaftplay, and built up too much heat in the bearings casing the oil to heat up and expand, etc. Who knows. Id have to see it.
Old Apr 26, 2004 | 07:16 PM
blkeg2's Avatar
do you use stock injectors?
Old Apr 26, 2004 | 10:11 PM
90civichb's Avatar
Default Re: D16 Turbo problems... [long?] (blksol62103)
yes... but right now Im looking for another z6.. my girlfriend screwed my current setup..
https://honda-tech.com/zerothread?id=844482
Any tips on building the new SOHC?
JTmoney
Nov 13, 2007 08:09 PM
Luchini
Feb 1, 2006 12:51 AM
SpoolnByYou
Dec 11, 2005 02:40 PM
QuickHonda
May 24, 2002 09:40 AM
92JDMSiR
Apr 22, 2002 10:25 PM
