p28 ecu w/ 93 dx harness VTEC QUESTION
Old Apr 12, 2004 | 02:00 PM
hatchedzex's Avatar
Default p28 ecu w/ 93 dx harness VTEC QUESTION
i got a p28 ecu but i dont have the si harness, how can i use my stock dx harness and run a cheater line from the siloniod to the ecu so the vtec will engage?
Old Apr 12, 2004 | 02:03 PM
JDMlyfestyle's Avatar
not sure if the DX harness has vtec or not but if it does not u need to run a wire to the D6 spot and to the A6 spot i believe. Correct me if im wrong i just forget what lines need to go there
Old Apr 12, 2004 | 02:09 PM
a1320honda's Avatar
Default Re: p28 ecu w/ 93 dx harness VTEC QUESTION (hatchedzex)
you basicaly said what you need to do. use your dx harnes and run a 2 new wires to the engine from the ecu. one will need to go to oil press sensor, and one for vtec. the third wire is a ground on the sensor. the vtec oil pressure switch is pin c14, and the solenoid is pin a15. hope this helps.
Old Apr 12, 2004 | 02:36 PM
2lua's Avatar
it a4= vtec soleniod, d6= vtec pressure switch.
JDMlifestyle you got one wire right. 1/2
a1320honda
Old Apr 12, 2004 | 02:37 PM
a1320honda's Avatar
Default Re: p28 ecu w/ 93 dx harness VTEC QUESTION (2lua)
oh im sorry, i was going on what the chiltons said.
Old Apr 12, 2004 | 02:38 PM
i was close tho!
Old Apr 12, 2004 | 02:41 PM
2lua's Avatar
Default Re: (JDMlifestyle)
at least you guys tried to help...
TeamRPM_ZC
Jul 14, 2008 08:36 AM
Bulli Kid
Jun 11, 2007 03:17 PM
Eibach95Civic
May 28, 2007 08:52 PM
B_SERIES_BITCHEZ!
May 21, 2006 08:49 PM
hatchback_al
May 31, 2004 03:05 AM
