Clicking from LF axle
This is only when im going forward and when im braking. When i turn i dont hear anything. I do not hear it all the time, mainly at slow speeds
<FONT SIZE="3">My CV boots are fine, not torn or ripped, and no grease or oil anywhere(both inner and outer)
</FONT>
my caliper is not loose
suspention is tight
i found this thread https://honda-tech.com/zerothread?id=689986 and my problems are the exact same as his.
Im taking my car to honda on monday to have them see if they can figure it out
HELP!!!!!!!!!!!!!!!!!!!!!!!!
</FONT>
suspention is tight
had this problem b4... in my case, it was the wheel bearing! i thought it was the axle, replaced those, still heard the annoying clicking... over time it got louder... and finally performed surgery and found that my wheel bearing went to ****.
HTH..
HTH..
well i just found this..... https://honda-tech.com/zerothread?id=284083
and some people are saying its my pads....AAAHHHHHHHHHHH to much info out there
Guest
Posts: n/a
take it to honda. I had this same problem for a while....then i realized it was b/c my secondary O2 sensor (which was pulled out when i installed my header....but i left it plugged in b/c it kept my check engine light from coming on) was swinging around inside my engine bay....then it finally fell off....problem solved
o VALTER o
May 23, 2007 02:05 PM
