Which weight motor oil for LS motor?
Old Apr 6, 2004 | 09:58 AM
silverb18's Avatar
Default Which weight motor oil for LS motor?
It's time for my first oil change with my swapped LS motor, which weight oil is everyone using? Is it the same as my old D16?
Old Apr 6, 2004 | 10:38 AM
Aeka GSR's Avatar
New User
Default Re: Which weight motor oil for LS motor? (silverb18)
you should always use the thinnest possible that you can get away with before you start burning it. This will keep your clearances as tight as possible. thicker oils tend to wear large clerances. With that being said, use 5w-30. There is 0w-20 out now, but i dont know if b series clearances are too big for it, you could try it, but if you get a bunch of clacking and oil burning, step up a grade.
Old Apr 6, 2004 | 12:22 PM
silverb18's Avatar
Default Re: Which weight motor oil for LS motor? (Aeka GSR)
ok, i already put some 10w30 in my LS, is that bad? Also, what weight oil should I use when I turbo, same?
Old Apr 6, 2004 | 01:22 PM
Kal's Avatar
Kal
5w30... for turbo, i suggest a heavier weight oil because they're thicker and won't burn due to thinning out as quickly.
Old Apr 6, 2004 | 01:32 PM
silverb18's Avatar
Default Re: Which weight motor oil for LS motor? (Kal)
Ok so let me get this straight. I should use 5w30 on my NA LS and when I turbo I should use something like 10w30. Also, with the 10w30 in my NA LS, what negative effects could happen?
Old Apr 6, 2004 | 02:36 PM
non-VTEC's Avatar
10W30 is perfectly fine for your LS. N/A or turbo
and since your in arizona i would recommend you stick with 10W30 from now on.
Old Apr 6, 2004 | 05:33 PM
ejprimo's Avatar
Default Re: Which weight motor oil for LS motor? (non-VTEC)
i say use a 10w-30 oil. the 10w-30 dino is better than the 5w-30 dino. for one, the 5w-30 dino isnt shear stable. too much viscosity improvers causes it to thin out fast. my favorite conventional oil is chevron supreme.
and 15w-40 if your going turbo.
Old Apr 6, 2004 | 05:42 PM
quiksheit's Avatar
Default Re: Which weight motor oil for LS motor? (ejprimo)
go to http://www.bobistheoilguy.com
great site. have learned a lot there
Old Apr 7, 2004 | 12:31 AM
silverb18's Avatar
Default Re: Which weight motor oil for LS motor? (quiksheit)
cool site.
Hectamoan
Feb 20, 2013 01:09 PM
wshondaman
Dec 22, 2006 08:40 PM
Vitesse
Jun 30, 2006 01:27 PM
Burke
Jul 7, 2003 11:25 PM
