What Oil to use in my LS turbo????
Re: What Oil to use in my LS turbo???? (Burke)
Man, you can just use regular oil. I went through the same questions when I first started boosting, but the guy that built my kit was the first to do LS/Vtec and he told me that there is no reason to run more expensive oil since it is a must to change it at least every 3K. I swap mine out at the most 2.5K. I just run Mobile 1 non-synthetic. I have had no problems....oil related that is.
My $0.02....Good luck
Re: (turbo craig)
Always use synthetic if you can afford it, it lubricates MUCH better, and it has a much higher thermal breakdown temperature over regular crude oils..
Mobil 1 full synthetic 5w-30 or 10w-30 wouldn't be a bad place to start... if you can afford it.
Re: (lazerus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lazerus »</TD></TR><TR><TD CLASS="quote">Always use synthetic if you can afford it, it lubricates MUCH better, and it has a much higher thermal breakdown temperature over regular crude oils..
Mobil 1 full synthetic 5w-30 or 10w-30 wouldn't be a bad place to start... if you can afford it.</TD></TR></TABLE>
Exactly... I use Mobil 1 10w30 at oil changes, but mostly Chevron 10w30 to top it off in between oil changes because its cheap and readily available at all hours and areas... I have noticed that I burn considerably less oil with full synthetic than with normal oil. B18B turbo btw
