NEED HELP!!
Old Apr 5, 2004 | 06:30 PM
phatboy's Avatar
Default NEED HELP!!
I have a jdm b16a first gen motor..in a 90 hatch...it doesnt pull when vtec comes on..it make a loud noise like its bogging...changed the ecu,distributor,wires,sparkplugs even got a new head but used the same cams and internals...still does the samething...then i got tired of it and gave it to my friend for cheap...its rewired in his car and everything does the same thing but this time only when the car is warmed up..when we drive it in the morining it pulls like a champ..but on the way back it boggs when vtec engages..can u guys help me..asap thanx
Old Apr 5, 2004 | 07:01 PM
phatboy's Avatar
Default Re: NEED HELP!! (phatboy)
bump need help peepz thanx
Old Apr 5, 2004 | 07:08 PM
Syner-G-Racing LLC's Avatar
try changing to a better oil...i dont know what your useing now but if it only does it when its warmed up its probly not enough oil pressure.
Old Apr 5, 2004 | 07:10 PM
hit me up with an I.M. I just moved here from FT hood tx, and Im looking for some locals to show me around to the tracks and stuff. Im at schofield barracks.
Old Apr 5, 2004 | 07:38 PM
phatboy's Avatar
Default Re: NEED HELP!! (Syner-G-Racing)
oil thats not the problem bro.i use that purple stuff..let me know peepz thanx
Modified by phatboy at 7:25 AM 4/6/2004
Old Apr 5, 2004 | 10:25 PM
phatboy's Avatar
can it be the oil pump?
Old Apr 6, 2004 | 12:11 AM
leadfoot78's Avatar
With a bad oil pump u would have bigger problems than just no vtec. I would take of the vtec solenoid and see if the screen inside is clean and everything looks good. Then check the oil pick up, it may be dirty or clogged and that might give u all kinds of problems. Then the most likely thing is the wiring, mostly the knock sensor, I've had my share of problems with the knock sensor, and I never really fixed it cuz u need shielded wire for it and I couldn't find it any were. I got a chipped P28 with no knock sensor and it worked great. Also check the timing and u should get a code if some thing is wrong with the wiring. I used to get the knock sensor code only when the car warmed up too. Good luck
Old Apr 6, 2004 | 12:51 PM
phatboy's Avatar
Default Re: NEED HELP!! (leadfoot78)
disconnected the vtec and it runs fine but without vtec..its hella slow but it doesnt bog so yea...the car has been wired by a shop..so it cant be messed up...would the cams cause this problem??
Old Apr 6, 2004 | 01:45 PM
leadfoot78's Avatar
so its not bad timing, and its not cams since it doesn't bog when v-tec is disconnected. It might be the v-tec solenoid or wiring, maybe the ecu. Do u get any codes?
Modified by leadfoot78 at 12:11 AM 4/7/2004
95lscivic
Nov 18, 2006 10:22 PM
allmotorcrx2001
Jul 5, 2006 08:20 AM
swappedcivic
Apr 22, 2006 07:32 PM
THugluv423
Jan 11, 2006 01:30 PM
93hybrid
Apr 10, 2003 07:36 AM
