Need help with a sputtering problem
Old Jul 5, 2006 | 05:45 AM
allmotorcrx2001's Avatar
Default Need help with a sputtering problem
My ITR for some reason when it hits 5600 RPM starts breaking up like I am on a 2step. No check engine light, fuel pressure, timming everything correct. All I did was take the head of and put bigger valves and different manifold and throttlebody on and since that the car does that. The car will drive fine up until you try to go in to VTEC. Any help would be appreciated.
Old Jul 5, 2006 | 07:14 AM
RTW DC2R's Avatar
oil pressure if the life blood of VTEC. check oil level, and if you removed the VTEC solenoid, make sure its reconnected and installed properly.
Old Jul 5, 2006 | 08:20 AM
Default Re: (clip the apex)
Yeah I did remove it when I took the head off, I am certain its on properly. The oil is on mark. Man I am beat with this problem.
jasonboyce03
Feb 28, 2012 06:37 PM
yeungkaho
Mar 21, 2007 04:59 PM
Phantastic
Nov 13, 2005 11:45 AM
SleepinTeg
May 26, 2005 05:32 PM
311
Aug 26, 2002 10:17 AM
