IM Nut/Stud Help!!!
Old Apr 4, 2004 | 11:17 AM
Dusty.'s Avatar
Default IM Nut/Stud Help!!!
Im trying to take off my IM and the center lower nut won't come off, it just spins around with the stud! any suggestions???? doubt it matters but its an full ITR head in a rex which means theres very little room as it is, Thanks!
Old Apr 4, 2004 | 11:47 AM
spaceman's Avatar
Default Re: IM Nut/Stud Help!!! (Dusty.)
can you take the stud out and then remove the bolt?
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dusty. &raquo;</TD></TR><TR><TD CLASS="quote">Im trying to take off my IM and the center lower nut won't come off, it just spins around with the stud! any suggestions???? doubt it matters but its an full ITR head in a rex which means theres very little room as it is, Thanks!</TD></TR></TABLE>
Just turn it on out. You can reinstall the stud in the head after the manifold is off.
Old Apr 4, 2004 | 12:41 PM
Dusty.'s Avatar
Default Re: IM Nut/Stud Help!!! (Chiovnidca)
yeah thats what I thought, but it just spins in there, I don't get it, I can't pull it out and I can't spin/turn it out, I don't understand what it could be doing there, I guess the stud is spinning but its still threaded enough to hold itself in there...any ideas anyone???????????//
Old Apr 4, 2004 | 12:45 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dusty. &raquo;</TD></TR><TR><TD CLASS="quote">I guess the stud is spinning but its still threaded enough to hold itself in there...any ideas anyone???????????//</TD></TR></TABLE>
Take the rest of the nuts off and pull on the intake to help get it out.
Old Apr 4, 2004 | 01:50 PM
Dusty.'s Avatar
i've been trying that also, i think im gonna try to find someone to pull while I turn, maybe that will work..
Old Apr 4, 2004 | 06:01 PM
Whitfield Inc.'s Avatar
Is the nut lose at all ? Any space at all between the manifold and head ? If so you could try and put a small screw driver in the space, and pry a bit to put pressure on the stud. Maybe it would hold it in place if not maybe it would put enouph pressure to make the stud come out?? Make sure not to push tooo hard or you could put a dent in it. Good Luck
Old Apr 4, 2004 | 08:35 PM
missdusty's Avatar
Default Re: IM Nut/Stud Help!!! (RageDzine)
unfortunatly i have a hondata IM gasket on there so that space is probably taken up, i will definitly give it a shot tommorow though...thanks jayson!
Old Apr 4, 2004 | 08:40 PM
Default Re: IM Nut/Stud Help!!! (missdusty)
Ya you will probably damage the gasket ???????? Man that sucks and its the one under the manifold so there is np way to try and grind or cut the bolt/stud. Wow the only other idea it to R-R the head but alittle costly on the parts and labor Wish you luck.
Old Apr 5, 2004 | 06:57 AM
doublejz's Avatar
that happens alot to people, the bolt is probably stripped and its just sitting in there spining since theres on threads left. If you did what was mentioned, use a screw driver and pry alittle under the nut while trying to unscrew it, it'll most likely come out. if not grind the nut off and remove the IM then use a pair of vice grips and pull and unscrew it at the same time
Old Apr 7, 2004 | 02:18 PM
WHITFIELD-TUNED's Avatar
DYNO-PRO
From: SoCal I.E 909, CA, where we innovate not immitate
Default Re: IM Nut/Stud Help!!! (doublejz)
if nothing else try to tighten the nut/bolt back in and crank on it untill it snaps off then repair with mainfold off (last ditch effort)good luck
Old Apr 7, 2004 | 06:32 PM
doublejz's Avatar
Default Re: IM Nut/Stud Help!!! (HOOKUPS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HOOKUPS &raquo;</TD></TR><TR><TD CLASS="quote">if nothing else try to tighten the nut/bolt back in and crank on it untill it snaps off then repair with mainfold off (last ditch effort)good luck</TD></TR></TABLE>
i think my idea of grinding the head/nut off would be better. If you break it off it may break in the IM which would cause a headache. If you just grind it flush with the IM you would have more of the bolt to work with
Old Apr 8, 2004 | 11:47 PM
Dusty.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doublejz &raquo;</TD></TR><TR><TD CLASS="quote">
i think my idea of grinding the head/nut off would be better. If you break it off it may break in the IM which would cause a headache. If you just grind it flush with the IM you would have more of the bolt to work with</TD></TR></TABLE>
yeah thats what I wound up doing, there was just enough room to squeeze a dremel in there from underneath and i just grabbed a replacement stud off a b16 head I have lying around, thanks for all the input guys!
B_Swapped93
Dec 2, 2013 08:14 PM
ToTriggerHappy
Feb 19, 2010 06:33 AM
B18C_EJ8
Oct 29, 2007 04:33 PM
yh23
Feb 18, 2007 12:13 PM
AznJohn33
Jan 10, 2004 08:58 AM
