No spark, please help
Old Apr 3, 2004 | 12:46 PM
yellow_jacket's Avatar
Default No spark, please help
Please see my thread in the Integra section. Thanks!
https://honda-tech.com/zerothread?id=820951
Old Apr 3, 2004 | 01:19 PM
kreush33's Avatar
Default Re: No spark, please help (yellow_jacket)
Yeah try a new coil just cause it tested out ok douesn't mean its good, First check to see if the coil is getting power. I just had the same problem with mine sorta. The coils only like 70 bucks so buy one and see if thats the problem if not then you can just return it. Your parts store should have one in stock for a GSR.
Old Apr 3, 2004 | 02:30 PM
showbiz's Avatar
how was it running before the new cap and rotor
Old Apr 4, 2004 | 06:05 PM
Default Re: No spark, please help (sedanman)
Car was running flawlessly before this happened. It just shut down like someone turned the key off. It was just being tuned up for routine maintenance.
The coil power is good. So is power to the ignitor. All fuses check out(test light and visual). I just hate to replace the coil and have it not be that. especially since the primary and secondary resistance are good. Plus I couldn't see any arc marks.
Thanks guys!
Old Apr 4, 2004 | 06:17 PM
showbiz's Avatar
It sound like there might be a problem with the new cap and rotor, check every connection. Are they identical to the old ones. Where did you get the new parts ?
Old Apr 4, 2004 | 06:36 PM
Cap and rotor came from napa. I actually switched back to the old cap and rotor, didn't make a difference. Because it ran so smoothly for about 20 seconds I wouldn't think that was it.
*EGK*
Sep 11, 2010 07:32 PM
zx96_r
Oct 17, 2009 08:31 AM
jax8686
Feb 7, 2005 10:04 PM
10seceg
Jan 26, 2004 08:54 AM
