just rebuilt ls motor and it smokes alot.....
Old Mar 31, 2004 | 12:18 PM
ensracer's Avatar
Default just rebuilt ls motor and it smokes alot.....
i just rebuilt my ls motor and its smoking alot. i have a turbo on the motor but am not sure if its the turbo or the car that is smoking. i did a compression check and its 190 all across... i have only driven it like 40 miles and the oil is super thin and black...help with some suggestions please
Old Mar 31, 2004 | 01:25 PM
doublejz's Avatar
Default Re: just rebuilt ls motor and it smokes alot..... (eduardo)
what color smoke?
Old Mar 31, 2004 | 01:29 PM
ensracer's Avatar
Default Re: just rebuilt ls motor and it smokes alot..... (doublejz)
black smoke
Old Mar 31, 2004 | 02:46 PM
junktronic's Avatar
What does it smell like? unburnt gas perhaps?
Old Mar 31, 2004 | 02:55 PM
Ditdogs's Avatar
Default Re: just rebuilt ls motor and it smokes alot..... (nlafferty)
What do you mean when you said rebuilt ls? Did you get new pistons new rods block girdle what? What oil are you using synthetic or non synthetic? What method did you use to brake in your motor? How many layer head gasket are you using, and is it after market or stock? Is the head sitting on the block flush? Did you mill the head? Where is the smoke coming from... you have to be more specific... bro…
Old Mar 31, 2004 | 04:40 PM
doublejz's Avatar
Default Re: just rebuilt ls motor and it smokes alot..... (Ditdogs)
black is probably fuel. Timing, stuck injector, dunno
Old Apr 1, 2004 | 10:56 AM
ensracer's Avatar
you know what the smoke is kind of white
Old Apr 1, 2004 | 12:30 PM
vteccrx909's Avatar
Default Re: (eduardo)
how did you rebiuld it did you put new pistions in it if you did you might have put the rings on upside down.
Old Apr 1, 2004 | 01:26 PM
98-ls's Avatar
Default Re: (vteccrx909)
the only way to fix it is to give me your turbo
Old Apr 1, 2004 | 01:59 PM
allmota1.8's Avatar
Default Re: (98-ls)
rings gap wrong
93egcoupe
Aug 20, 2006 08:06 PM
1SlowSi
May 20, 2005 10:01 AM
newBcrxer
Aug 27, 2004 08:00 AM
Chuji
Dec 22, 2002 12:50 PM
synergy004
Mar 12, 2002 07:02 AM
