turbo car won't pick up when vtec kick in
Old Mar 30, 2004 | 07:16 PM
DXK Eg's Avatar
Default turbo car won't pick up when vtec kick in
Hi, like i said my car won't pick up when vtec kick in. It feels like i'm redlineing but i'm only at 5000 rpm. I check if it was a boost leak but it wasn't. Any idea what this can be??
Old Mar 30, 2004 | 07:22 PM
VNTEC's Avatar
B A N N E D
Default Re: turbo car won't pick up when vtec kick in (dynasty-x-motorsport)
Is your tuning off?
Old Mar 30, 2004 | 07:24 PM
DXK Eg's Avatar
Default Re: turbo car won't pick up when vtec kick in (VNTEC)
it's just a drag turbo kit with a fmu. So i don't have a clue what it is? I'm i losing oil pressure?
Old Mar 31, 2004 | 02:21 AM
pornstarSR's Avatar
where do you have the oil feed line for the turbo connected..
some people run it off the front of the head near the header and vtec solinoid....thats a NO NO...oil pressure there isnt consistent. and when vtec is engaded the turbo sucks all the oil away from it...
let us know exactly how you have everything run(installed) easier to answer with details
Old Mar 31, 2004 | 06:34 AM
DXK Eg's Avatar
Default Re: turbo car won't pick up when vtec kick in (pornstarSR)
The oil line is installed next to to oil filter where it should be or could it be that i'm low on oil i just check. Is that why i'm going to put in some oil and take it for a test drive and see what happens..
Old Mar 31, 2004 | 10:58 AM
pornstarSR's Avatar
that was my next suggestion...
to little oil in a stock vtec car will make the vtec not engaged.... and in a turbo car since it has to feed the turbo too....
check that let us know
GaVO311
Sep 12, 2006 08:30 PM
Cowboy
Mar 24, 2004 09:16 AM
Griffin@Camtech
Feb 24, 2004 05:58 PM
burner
Oct 17, 2002 07:50 PM
2000_Civic_Si
Feb 28, 2002 11:19 PM
