can someone explain wideband to me?
Old Mar 28, 2004 | 01:09 PM
Btothe3rdDegree's Avatar
Default can someone explain wideband to me?
i have read some threads, but they mostly explain installation. i wondering what a wideband does? when is it needed? i am going to run a built d16 on uberdata. thanks guys
Old Mar 28, 2004 | 02:11 PM
RyanEJ8's Avatar
Default Re: can someone explain wideband to me? (Btothe3rdDegree)
The stock o2 sensor is a narrowband sensor. It only has a range of 0-1 volts. Basically it was only engineered to tell you if the engine is running at stoichiometric conditions (14.7:1). This Stoich level isn't even what you would tune a boosted or nitrous car for, this would only apply to an N/A tune.
A wideband o2 can read from 0-5 volts and gives a much more accurate reading. This is engineered to be accurate and read air/fuel at different levels than stoich (rich or lean).
Old Mar 28, 2004 | 02:27 PM
Default Re: can someone explain wideband to me? (RyanCivic2000)
is it required for a turboed car? what are the differences? i have seen some for 200 and some for a grand
Old Mar 28, 2004 | 03:21 PM
scttydb411's Avatar
not required, but necessary to tune. narrowband will never let you know that you are running rich enough for boost.
you could just go to a dyno that has a wideband and tune it and then leave it alone. the only problem with not having one installed daily is that you could have a situation in which your car leans out or becomes untuned and you don't know until...boom!!
Old Mar 28, 2004 | 03:42 PM
Default Re: (scttydb411)
whats a good one? why the diifernece in price?
Old Mar 28, 2004 | 06:15 PM
x2gold's Avatar
Default Re: (Btothe3rdDegree)
I've had good success with the Innovate. They are quite popular and are a great price. Innovative Motor Sports I belive is the name of the company.
Old Mar 28, 2004 | 06:19 PM
skellator_thoj's Avatar
Default Re: (x2gold)
does anybody know the website addy to Innovative Motor Sports??
Old Mar 28, 2004 | 07:10 PM
scttydb411's Avatar
i use the techedge 2.0 and it's pretty inexpensive.
Old Mar 28, 2004 | 07:14 PM
PHiZ's Avatar
Default Re: (skellator_thoj)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skellator_thoj &raquo;</TD></TR><TR><TD CLASS="quote">does anybody know the website addy to Innovative Motor Sports??</TD></TR></TABLE>
http://www.innovatemotorsports.com/
This should clarify a lot of wideband questions, hopefully:
https://honda-tech.com/zerothread?id=635792
-PHiZ
Old Mar 29, 2004 | 09:49 AM
Default Re: (PHiZ)
hey thanks phiz!! so a normal O2 sensor won't give you a accurate reading where as a wideband will? also they can be used as datalogging right? since uberdata doesn't have datalogging (yet) a wideband would be a good idea? or is it not nessesary
Old Apr 4, 2004 | 05:22 PM
turboteg2nv's Avatar
yes so can the innovative motorsports wideband datalog?
Old Apr 4, 2004 | 05:43 PM
TeamCracka's Avatar
Default Re: (turboteg2nv)
Here's a graph of a wideband O2 sensor's voltage range:
And here's a graph of the stock narrowband sensors, notice the cutoff and "accurate" range.
juniordc2
Dec 27, 2017 01:51 PM
Harassing Herbs
Apr 8, 2005 01:35 PM
uptownrickyv
Jul 2, 2004 11:02 AM
90teg
Jul 5, 2003 10:32 PM
Westrock2000
Feb 25, 2002 05:20 PM
