removing turbin and shaft
Old Mar 28, 2004 | 01:00 PM
regime's Avatar
Default removing turbine and shaft
THIS HAS BEEN SEARCHED not just on Honda tech, but EVERYWHERE
im trying to get the shaft out of a t3 .60 .48 turbo and the damn thing wont even move.
everything i read says to just tap <U>lightly </U>with a dead blow
or press the shaft out. and that its very rare for them to just slide out.
well I've pressed it and no luck
I've tapped it and no luck
so basically how the hell do i get it out..
PS.. yes i do have the compressor wheel off
any help would be great guys
edit: hehe turbin shaft.... shoulda spell checked that
Modified by regime at 5:36 PM 3/28/2004
Old Mar 29, 2004 | 10:42 AM
regime's Avatar
Default Re: removing turbine and shaft (regime)
come on someone has to know this, and is willing to help me out
Old Mar 30, 2004 | 07:58 AM
regime's Avatar
plz
Old Mar 30, 2004 | 08:08 AM
VNTEC's Avatar
B A N N E D
I just took one apart... I pryed it out from the back plate.. worked fine
Old Mar 30, 2004 | 08:26 AM
Bontke's Avatar
Default Re: removing turbine and shaft (VNTEC)
I just dissasembeled a T4 unit and the shaft was stuck from coked oil. I had to spray WD40 in the shaft from inside the oil feed/return holes and let it stick. After a while the coked oil gave and I puled the shaft. I don't know what else could be holding it together.
Old Mar 30, 2004 | 08:53 AM
Turbo E's Avatar
galled shaft is prolly the culprit.
Old Mar 30, 2004 | 04:53 PM
regime's Avatar
Default Re: (Turbo E 604)
im gunna give it a shot with the wd40 and see what happens. thanks ill let ya know
GsrIntegra789
Apr 20, 2008 07:30 PM
R6E6I6D
Aug 23, 2005 10:50 PM
j-specB20sol
May 11, 2004 10:41 PM
under_psi
Mar 27, 2003 03:42 PM
