Is this shaft good.?
Old Apr 18, 2008 | 07:45 PM
GsrIntegra789's Avatar
Default Is this shaft good.?
I took my turbo apart and have a question about the shaft. on the turbine there seems to be a ring and then a bit after that there is another groove. is there supposed to be a ring there also? i have the area boxed in. also how far is the shaft supposed to go in? and also i have noticed that there are grooves on the shaft i dont know if theyre supposed to be there someone take a look. (picture 2) someone help me out
Modified by GsrIntegra789 at 9:58 PM 4/18/2008
Old Apr 19, 2008 | 04:49 AM
Default Re: Is this shaft good.? (GsrIntegra789)
someone has to know something. help me out
Old Apr 19, 2008 | 10:50 AM
BUMPPPPP
Old Apr 19, 2008 | 01:45 PM
come on guys 120 views and none can answer my question? this is the forced induction section someone definetly knows how the shaft on a t3/t4 is supposed to look.
Old Apr 19, 2008 | 01:56 PM
flaco0018's Avatar
http://www.gpopshop.com/garrettt3kits.html
google
Old Apr 19, 2008 | 02:10 PM
Default Re: Is this shaft good.? (flaco0018)
ive seen this already..that dont help me the pictures arent specific enough when it comes to the end of the shaft. i cant make out according to the picture of there is a ring there or not
Old Apr 19, 2008 | 03:16 PM
boostedb20z's Avatar
the grooves are suppost to be there and the groove on the hot side there is not suppost to be a ring there just one ring. what i do is i tape up the shaft and them i take the ring out and sand blast the wheel and the lil groove and i sand blast everything and when you are done sand blasting the wheel take 1000 grit sand paper and sand the shaft then take 2000 grit and then all the burnt oil makers should be gone. hope this helps
Old Apr 19, 2008 | 05:16 PM
lude27's Avatar
Default Re: (boostedb20z)
thank you for your info finally someone helped. what about the second picture? are those grooves ok/?
Old Apr 19, 2008 | 09:23 PM
that is where the thrust washer rides and thats ok
Old Apr 20, 2008 | 09:49 AM
thanks i have one more question. How far in is the shaft supposed to go? the ring on the shaft is sort of a stopper/sealer correct? when im putting the turbine back in do i just leave the ring on the edge where it seems to be like a groove?
Old Apr 20, 2008 | 07:30 PM
what i do is i put the shaft in and spin it then tap it in with my hand it will snap in
R6E6I6D
Aug 23, 2005 10:50 PM
regime
Mar 30, 2004 04:53 PM
5STAR3
Jul 15, 2003 09:53 AM
under_psi
Mar 27, 2003 03:42 PM
