removing turbin and shaft
removing turbine and shaft
THIS HAS BEEN SEARCHED not just on Honda tech, but EVERYWHERE
im trying to get the shaft out of a t3 .60 .48 turbo and the damn thing wont even move.
everything i read says to just tap <U>lightly </U>with a dead blow
or press the shaft out. and that its very rare for them to just slide out.
well I've pressed it and no luck
I've tapped it and no luck
so basically how the hell do i get it out..
PS.. yes i do have the compressor wheel off
any help would be great guys
edit: hehe turbin shaft.... shoulda spell checked that
Modified by regime at 5:36 PM 3/28/2004
Re: removing turbine and shaft (VNTEC)
I just dissasembeled a T4 unit and the shaft was stuck from coked oil. I had to spray WD40 in the shaft from inside the oil feed/return holes and let it stick. After a while the coked oil gave and I puled the shaft. I don't know what else could be holding it together.
how much shaft play is too much shaft play? and is there such thing as a natural amount of shaftplay
b18sihatch
04-12-2006 08:17 AM
R6E6I6D
08-23-2005 10:50 PM
