Which vacuum line, when leaking, causes a loopy idle?
Old Mar 27, 2004 | 09:48 PM
Spec R's Avatar
Default Which vacuum line, when leaking, causes a loopy idle?
Old Mar 28, 2004 | 01:50 PM
AllmansDB8*'s Avatar
Default Re: Which vacuum line, when leaking, causes a loopy idle? (Spec R)
??? How do you know that it is a vacuum line???
Low coolant could cause a lopey idle
Bad IAC could cause a lopey idle.
believe it or not, low brake fluid could even cause a lopey idle.
Give us more information
Old Mar 28, 2004 | 07:29 PM
Bay_707's Avatar
My car (95 gsr) and my friends civic with a gsr swap has the same problems. Some bolt was loose on my intake manifold which caused this. Try to tighten everything down if u havent..
Old Mar 28, 2004 | 08:13 PM
deepgreengsr's Avatar
Default Re: Which vacuum line, when leaking, causes a loopy idle? (707_Eclipse)
Any vaccume leak would cause a crap idle. and first off, can you hear a leak? if not check one of the other sugestions.
Old Apr 8, 2004 | 09:42 AM
Spec R's Avatar
Default Re: Which vacuum line, when leaking, causes a loopy idle? (deepgreengsr)
whoops i forgot to check this thread, my car is fine, i was just wondering for the sake of one of my classmates who wants to fool people he has cams. same guy also like to run on three cylinders to make his car sound like a wrx.
Old Apr 8, 2004 | 10:22 AM
Integra4lyfe's Avatar
take it to a shop and they can use a machine and immediantly tell which line is leaking, I'm taking my car today to get it fixed.
Old Apr 8, 2004 | 10:26 AM
SuzukaBlueAP2's Avatar
Default Re: Which vacuum line, when leaking, causes a loopy idle? (Integra4lyfe)
If your friend wants to be "cool" and make his car sound like that, just unplug the IACV. It fools people.
Reason I know is, I had an IACV that needed changed before, so, to stop the bouncing idle, I unplugged the IACV. It idled like a Harley then. lol One afternoon I went to the track to watch some racing, and the guy parking people was like "got some aggressive cams, eh?" lol
weaslehunter1
Jan 26, 2015 03:49 PM
WhiteTrashedDA9
May 2, 2013 08:40 AM
G. Man
Classic Hondas
Jun 25, 2011 07:48 PM
92_Lude_Si
Mar 8, 2006 08:29 PM
UNKNOWN_MEMBER
Aug 11, 2005 08:55 PM
